T56 crossmember same for LT1 and LS1?
Car: '89 Firebird
Engine: 7.0L
I browsed BMR website and I notice they only sell one crossmember for T56. Is the crossmember independent of engine type, or do I need a specific design for LS swap?
Same question goes for their TH400 crossmember with LS engine.
Thanks!
Thanks!
Car: 91 Firebird
Engine: 6.0
Re: T56 crossmember same for LT1 and LS1?
Crossmember works for both motors.... trans has to be in a certain spot....
Car: '89 Firebird
Engine: 7.0L
Thanks. Didn't know if there were changes to the back mounting location of the trans over the years.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
This is what i had to do to mine with the straight up swap mounts and not using the 1 inch set back, so you can imagine, the 1 inch set back plates or other mount that positions everything in the correct location, the original holes would probably work perfect:
TOMcat GTA
Sep 15, 2015 09:31 AM
mygta87
Sep 14, 2015 10:36 PM
89, camaro, conversion, cross, crossmeber, crossmember, crossmemeber, ls1, lsx, lt1, ltx, member, sphons, swap, t56
