LS/T56 swap, shifter base hitting floor
Car: 1983 Camaro Z28
Engine: soon to be an LS1
Transmission: soon to be a T56
Axle/Gears: 9 inch rear 3:70
My buddy and I are doing an LS1/T56 swap into his 85 firebird. We are using the Spohn conversion motor mounts and tranny crossmember. The crossmember is about 2 inches from bolting to framerail and the back of the shifter base is hitting the floor. Before we start modifying the floor we wanted to verify that is indeed what needs done. Thanks in advance for any help.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: LS/T56 swap, shifter base hitting floor
well the floor has to be open before the trans can sit high enough. the rear of the shifter will sit higher than the sheet metal in the tunnel
yes that is what you need to do. notch a little out of the back of the old shifter hole. i think i only took 1-1.5" out on mine, which is essentially the same setup sounds like.
Thanks Techrunner. That is exactly how much we were thinking about having to notch. We wanted to hear from someone else before we starting to cut just to make sure.
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 25, 2015 11:49 PM
