What do you all think of this donor?
Old Mar 1, 2011 | 06:56 PM
ssantac's Avatar
Car: 83 Trans Am
Engine: Soon to be 6.0l LQ9
Transmission: Soon to be 4L60E
I cant do anything until fri due to work, but I'm thinking of calling this guy a lil closer to the day and seeing if I can go check this out....are there any particular questions I should ask in regards to his swap?
Thanks.
http://phoenix.craigslist.org/evl/cto/2239895645.html
Old Mar 1, 2011 | 07:06 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: What do you all think of this donor?
Just make sure its a 6.0L and not a 5.3L.
Old Mar 1, 2011 | 07:59 PM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Looks like it's a pretty good deal to me. I'm sure there is a way to verify that it's a 6.0L before you buy it. Good luck with it
Old Mar 2, 2011 | 06:05 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
If thats actually a 6.0... And its not hacked all to pieces, which it shouldnt be since the 6.0 long block is a drop in more or less...then that is a heck of a deal Ide say.
Just as a heads up... I sold the entire front clip off my 99 donor car as a conversion package for like $800 alone. So you can get a NICE chunk of money back parting out the shell when youre done with it. Looks pretty straight..aside from the paint issues.
J.
Old Mar 2, 2011 | 06:41 PM
ssantac's Avatar
Car: 83 Trans Am
Hey thanks guys...I'm going down to check it out tomorrow. I know that the is stamped into the block, but I heard it might be covered by the water pump...is there any other markings or casting #'s that will positive ID it as a 6.0?
The guy said it was from a 2010 Escalade if that makes any difference.
Old Mar 2, 2011 | 07:07 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
2010?! wouldn't that be a vvt motor?
Edit: just checked and a 2010 escalade would have an aluminum 6.2L with VVT.
Old Mar 2, 2011 | 07:58 PM
ssantac's Avatar
Car: 83 Trans Am
Ok, thats something I didnt think of and I know I should have. I'm searching now, but is that a bad thing? The cars a runner so he must have done whatever is needed to make it work in a camaro, which should in theory translate to the third gen right? or am I being too optimistic?
Old Mar 2, 2011 | 08:08 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
There's alot of shady people in this world looking for a quick buck, good luck man.
Old Mar 2, 2011 | 08:13 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Your best bet would be to check the casting number on the cylinder heads. Because if someone went through the trouble of swapping an iron block and only wants 4k for it odds are the long block was left alone.
Old Mar 2, 2011 | 08:15 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Oh and I meant that there is no way there is a 2010 escalade motor in there. The motor alone would be worth more then that. Have fun.
Old Mar 2, 2011 | 08:29 PM
ssantac's Avatar
Car: 83 Trans Am
Well I called the guy back and I was wrong on the year. It was from a 2008 and he said it does not have VVT. We'll see how it works out.
Old Mar 3, 2011 | 12:39 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Thats the same block I used for my LS build. Hard to verify it, though.... Good luck to you. You can also use the rear axle and brakes (All around) for your car.
Old Mar 3, 2011 | 05:27 PM
ssantac's Avatar
Car: 83 Trans Am
Well I did it...
It seems to run good, good oil pressure, pulls well, shifts crisp. The only way I guess its still unkown if its a true 6.0, but it has the 317 heads, and an ls1 intake. Supposedly it has the B4C police package too, I'll have to try and verify that. But so far I'm happy...we'll see when I try to pull it next week.
Old Mar 3, 2011 | 06:31 PM
dprest68's Avatar
Engine: cammed LS1
Score! Sounds like your plan is coming together
Old Mar 3, 2011 | 08:25 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Well I did it...
If that is a 2008 Caddy engine then you have a great platform to make a wicked car. Get the heads fully ported, change the cam, and put on a LS6 intake and you'll have an 11 second car. Simple but very effective.
Old Mar 4, 2011 | 03:02 AM
Good deal!
Old Mar 5, 2011 | 08:53 AM
ssantac's Avatar
Car: 83 Trans Am
Thanks guys...your advice has so far probably saved me a lot of money and headache.
I also took the vin to the dealer and they gave me the RPO code list for this car, and it is indeed a B4C police package car.
I'll probably start a teardown/build thread soon. When I get some time off I will start working on pulling the ole crossfire/700r4, and hopefully notching the k member.
Old Mar 5, 2011 | 11:21 PM
I might trade you a T-56 for the rolling chassis if you are interested. I collect B4c's...
rubblerubble
Mar 13, 2016 06:57 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
thunder57
Nov 7, 2015 02:28 PM
LittleFranks
Oct 7, 2015 11:26 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
