Need help understanding the torque arm mounts ls1/t56
Old Mar 5, 2011 | 12:40 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Hey guys,Im ordering all my swap parts..mostly from hawks.I need a clear understanding about the options of mounting the torque arm and the advantages of relocating it or not.
My plan is the buy the hawks motor and t56 mount package,but I noticed they sell 2 type of ls1 t56 cross members:
Part #HT-T56XM
Part #SP-LSXT56XM
Now I do plan on getting longtube headers eventually which the first crossmember is the better choice.Then I found this torque arm mounted with the cross member that they sell aswell:
Part #SP-332
This gives me a new torque arm with t56 mount and optional driveshaft loop.But my question is,since i want to get this on the road asap.Can I A)use my stock torque arm with the t56 and just buy the double hump cross member B) Buy the new torque arm with cross member and ditch the stock arm.
What are the pros and cons of a trans mounted arm compared to a relocated arm mount? I dont plan on making much over 400hp to the wheels and its a street car which rarely sees track time.
Old Mar 5, 2011 | 01:27 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: Need help understanding the torque arm mounts ls1/t56
I'm in the same situation as you. I think I will most likely go with the double hump since I want true dual exhaust it might make it easier
Old Mar 5, 2011 | 01:33 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
I wont be doing true duals but maybe long tubes with 3inch collectors and 3inch y pipe later on.I still want to confirm if I can use my stock torque arm with the t56 or should I relocate it from the start.
Old Mar 5, 2011 | 07:04 AM
Pocket's Avatar
Car: 91 Trans Am
Yes the stock TA fits the T56. Early TAs had the ridges reversed in the bushing but even those are no sweat, just swap the bushing into the T56 mount
Go with the double hump crossmember even if you're not running duals. Its really difficult to cram tubing under the trans and make a Y before that section. Most people including myself Y-ed just after the tailshaft
Old Mar 5, 2011 | 09:27 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
Thanks Pocket, i will go ahead and order the parts i need.To what advantage is there in relocating the TA off of the trans itself?
Old Mar 5, 2011 | 09:30 AM
Pocket's Avatar
Car: 91 Trans Am
Less strain on the trans/rubber mount, you set the pinion angle best for your setup
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
