View Poll Results: How much will it make?
Voters: 15. You may not vote on this poll
Dyno next sat!!!
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
Dyno next sat!!!
So, just want to know what people think ill put down.
Not sure if its a dynojet, mustang or what. its a third gen meet up, ill get lots of pics and video.
car is an 88 trans am GTA
2002 ls1 w/ 45,000 miles on it.
Ported tb
Ud pulley
Ac delete
Air delete
Ls6 intake
Cold air intake w/ k n
1 3/4 lt's
ory
Slp loudmouth exhaust
Iradium spark plugs
Msd wires
Lpe gt2-3 cam (207/220 .573/.580 118.5 LSA)
Patriot gold springs
Harend push rods
T56
Ford 9", 31 spline axles, locker, 4.11 gears.
Last time I was at the track I trapped 111.84, and that was b4 the cam. Car weight was 3300 wn driver.
Ported tb
Ud pulley
Ac delete
Air delete
Ls6 intake
1 3/4 lt's
ory
Iradium spark plugs
Msd wires
Harend push rods
T56
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: Dyno next sat!!!
as a reference my car had a trap speed of 120.29 mph last year after i had it tuned and dyno'd... on the dyno i had 448 rwhp at hutter performance who uses a mustang dyno... my car weight is basically the same as yours... i have a ls3 with cam, headers, etc with t56 and 9" with 3.70 gears
Engine: 2002 Ls1
Transmission: t-56
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
It will all depend on the dyno. My buddy put down 335 with cai and lt headers on. 02 ls1/t56 swapped car
Engine: 2002 Ls1
Transmission: t-56
YEa, same year motor I have, the cam adds another 30 rwhp on n/a cars, I think 370 myself.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Lets see, stock heads, small camshaft, long tube headers with a T56. Maybe 360rwhp.
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
no.. i call 355rwhp +/-5
my 98 LS1.. stock heads.. GM ASA 226/236 .525 on 110*, LS6 springs, LS6 intake, BBK 80mm TB, TSP rumbler catback (just like the SLP catback) Pacesetter 1 3/4" long tubes with 3" ORY, LID with K&N, tune, made 372rwhp on a DynaPack 5000.. and 395rwhp on a DynoJet..
the Dynapack5000 # is more realistic because you cant preload the car on the rollers, mess with tire pressure, cause there are NO rollers, it uses hubs bolted to the car, cant fool the equipment.
good luck, let us know what you pull.
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Engine: 2002 Ls1
Transmission: t-56
I guess its better to guess low, so if its higher ill be happy lol
Engine: 2002 Ls1
Transmission: t-56
Engine: 2002 Ls1
Transmission: t-56
2001 SOM SS Vert GT2-3 cam (207/220 578/580 118.5 lsa) Manley hardened pushrods/ comp 918's FRTA/ LG Lid FLP headers with the cats on ASP Pulley/ Magnflow Muffer with SLP exhaust stock gears with a six speed Drives great and has a stock idle.. Pulls strong from 6500 6500 Made 370 rwhp and 354rwt. I was hoping to see mo quick for a vert. quick for a vert.
Post I found on ls1tech.com
360-370rwhp
Your cam is only giving you about 15rwhp since it's on the small side but ideal for FI
What does your intake system consist of? 85mm MAF?
Also, do 9" loose power like 12 bolts?
Engine: 2002 Ls1
Transmission: t-56
Maf is just stock.
Not sure what a 9" eatsup., but I also dont have cats.
Engine: 370 LSX
If I remember correctly the 9" will eat 10-15 rwhp over a stock 10 bolt.
Engine: 2002 Ls1
Transmission: t-56
Engine: 2002 Ls1
Transmission: t-56
Engine: 370 LSX
Car sounds good. It might be just because it's a vidEo, but seems like it should rip away with those 4.11 gears. I'm still voting 360.
Engine: 2002 Ls1
Transmission: t-56
Engine: 2002 Ls1
Transmission: t-56
Car: 1988 Iroc-Z
I say approx 395hp/380tq on Dynojet and 380/365tq on a Mustang.
Damn rear end and stock heads are going to be the killer.
Engine: 2002 Ls1
Transmission: t-56
Engine: 2002 Ls1
Transmission: t-56
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
majority of bolt on LS6 intake ls1's with a t56 behind them put down near 350whp. That cam should help get another 10-15whp more atleast!! I voted 370-380whp
Engine: 370 LSX
Hopefully you punched him right in the dick and redeemed his friend card.
Engine: 2002 Ls1
Transmission: t-56
Engine: 370 LSX
Lol that blows. Probably shouldn't punch him then.
Engine: 2002 Ls1
Transmission: t-56
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
LT1Formula
Oct 8, 2015 08:34 PM
HoosierinWA
Oct 7, 2015 10:15 AM
