700r4 to 4l60e swap
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
700r4 to 4l60e swap
so my buddy asked me if i can help him out. he has a 87 trans am that he had a shop put a lt1 into years ago. when they did the install i guess he told them to use the 700r4. he now has a 4l60e installed but needs it wired up. he says everytjinh was from a 94 lt1. my question is... does someone have a wiring diagram or something that shows how to wire up the 4l60e?
thanx in advace
thanx in advace
Car: 1986 Firebird
Engine: 6.0L LSX
Re: 700r4 to 4l60e swap
Can't help you much on the wiring but you could try this http://www.lt1swap.com/all_lt1.htm and at figure out what pins you need at the ECM. I've added the tranny side of the wiring so you know which pins do what at the transmission.
Make sure he has the 4th gen torque arm mount if he is going to use his original torque arm and mounting location at the tranny. Ask me how I know
Transmission: 4L80E/4L80E
If everything was from a '94, and from an automatic donor, the wiring should already be there.
Car: 1987 IROC
i guess the shop cut that part out fo the harness when they installed it. i dont really know all the facts yet. he just asked me if i can wire it up and that the trans is already in the car.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
