My 91 Camaro LS1/T56 Swap
Old Mar 8, 2011 | 11:18 PM
91_rs-teal's Avatar
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
Hey guys ive recently decided to make the big switch.
Im headin to get engine and trans this upcoming weekend, and tonight i pulled out the fuel tank to put in the much needed Walbro 255.
Planning on just doing headers, a nice intake and calling it good for now.
There's already 4.10's in it, so itll be plenty peppy
Attached Thumbnails My 91 Camaro LS1/T56 Swap-fuel-pump-fun-003
Old Mar 9, 2011 | 05:08 AM
Demon355's Avatar
Re: My 91 Camaro LS1/T56 Swap
Welcome to the club dude!
Old Mar 9, 2011 | 07:27 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i second that, welcome to the club. make sure you post pictures!
Old Mar 11, 2011 | 07:45 PM
91_rs-teal's Avatar
hawks mounts time for a little cleanin
Attached Thumbnails My 91 Camaro LS1/T56 Swap-mounts-008-edit.jpg
Old Mar 12, 2011 | 12:17 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Wow, another member that doesn't go for the red painted aftermarket stuff. We're a rare breed, you know...
Either don't get sticky tires, or don't do clutch drops with that 10-bolt. It won't stay peppy very long if you do both (ask me how I know).
Old Mar 15, 2011 | 07:48 PM
91_rs-teal's Avatar
the rest of the T-5 stuff pulled, who wants em? for sale soon
Attached Thumbnails My 91 Camaro LS1/T56 Swap-pedals-hydro.jpg
Old Mar 15, 2011 | 08:03 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I hope you've at least upgraded to a posi 10 bolt
Old Mar 15, 2011 | 08:04 PM
BlueZee28's Avatar
Why are you selling the pedals if you're going with a T56? You can re-use them, just do a search in here for my little remedy for making the 3rd gen pedals work with a 4th gen master cylinder. It cost me a whole $5.
Old Mar 15, 2011 | 08:50 PM
91_rs-teal's Avatar
o yea auburn posi unit, had richmond gears installed by a local rear end shop. hopefully getting my swap with 4th gen pedals
Old Mar 15, 2011 | 09:08 PM
BlueZee28's Avatar
The 3rd gen pedals are better than 4th gen ones, FYI. They're a lot more sturdy and will give the firewall more support when bolted down.
Old Apr 16, 2011 | 11:26 AM
91_rs-teal's Avatar
Finally picked up a motor, its a 2000 LS1 with 67k and its squeaky clean inside.
goin to pick up a trans tmrw
Attached Thumbnails My 91 Camaro LS1/T56 Swap-ls-002-edit.jpg   My 91 Camaro LS1/T56 Swap-ls-003-edit.jpg
Old Apr 24, 2011 | 01:49 PM
91_rs-teal's Avatar
test fit this weekend, got the mounts tightened up, snapped a very exciting pic of it sittin in there
Attached Thumbnails My 91 Camaro LS1/T56 Swap-ls-sittin-edit.jpg
Old Apr 24, 2011 | 03:48 PM
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
Wow, that looks very sexy. Cant wait to have this moment myself. Keep it up!!
Old May 4, 2011 | 08:58 PM
91_rs-teal's Avatar
got the TB polished and coated. also finally got my coils, and my rail covers
Attached Thumbnails My 91 Camaro LS1/T56 Swap-rail-covers-002.jpg
Old May 4, 2011 | 10:31 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Nice!
Subscribed..
Old May 10, 2011 | 07:33 PM
91_rs-teal's Avatar
the modding of the stock harness... gotta love it
Attached Thumbnails My 91 Camaro LS1/T56 Swap-wires-edit.jpg
Old May 16, 2011 | 12:26 AM
91_rs-teal's Avatar
thx for the comments!
this weekend, i got the engine and trans in, running manifolds so i fabbed up a y-pipe to my flowmaster 80 series out back with a slp res. in between.
Attached Thumbnails My 91 Camaro LS1/T56 Swap-l-s-1-edited.jpg
Old May 19, 2011 | 03:07 PM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Update???
Old May 19, 2011 | 04:54 PM
91_rs-teal's Avatar
yeah I was waiting on alot of parts, can barley get my hands on a f-body main alt. bracket.
gettin ready to go tap the water pump for the head crossover tube.
this weekend gotta place my o2's on the y-pipe, lay the harness out, extend it to reach inside the car. install new throttle cable, button up the pedals.
i think by Memorial day weekend itll b ready to fire
Old May 19, 2011 | 04:59 PM
91_rs-teal's Avatar
also before i threw it in, i decided on getting a cam. came across
http://www.summitracing.com/parts/LUN-55005LUN/
used at a good price.
I had a set of Z06 yellow springs and LS2 chain sittin around so i put those in... i plan to get it turned shortly after gettin it goin if all goes well
Old May 19, 2011 | 09:42 PM
91_rs-teal's Avatar
a couple more things fabbed up, i forgot how much it sux putting AN fittings on!
only got the one done
Attached Thumbnails My 91 Camaro LS1/T56 Swap-engine-pic-may-19.jpg
Old May 20, 2011 | 06:35 PM
daddy33's Avatar
Car: '85 Camaro
its looking pretty clean!
what are you going to use for power steering? I figure a stock ls1 unit, but as far as the lines go?
Old May 20, 2011 | 08:21 PM
91_rs-teal's Avatar
i have the stock ls1 unit as well, waiting on the brace that goes behind the pulley. you need a hi-pres. hose for a 98 Camaro.
Old May 22, 2011 | 03:00 PM
91_rs-teal's Avatar
harness 90 % done, ran outa loom to go along the rail. by the time its done you will only see the red on the vette covers, and fuel lines!
Attached Thumbnails My 91 Camaro LS1/T56 Swap-engine-harness.jpg
Old May 29, 2011 | 06:14 AM
91_rs-teal's Avatar
it runs! doesnt idle right, so gotta get a scanner hooked up. idles rich and when you stab it, it wants to stall.
still gotta install the wonderful pedal assembly and bleed the clutch out.
then its time to drive
Attached Thumbnails My 91 Camaro LS1/T56 Swap-engine-bay.jpg
Old May 29, 2011 | 04:26 PM
hartsmike's Avatar
Axle/Gears: 273
Keep us UTD.
Old May 30, 2011 | 11:29 PM
91_rs-teal's Avatar
put new o2's in it, still ran rough. felt the exhaust on the drive side, ice cold. forgot a wire in the harness for keyed on power to coils and injectors. plug it up runs like a top! waaay more than i expected this thing to have for power. very excited to drive this thing and get it to the track
Old Jun 2, 2011 | 04:21 PM
91_rs-teal's Avatar
12.74 1/4 @ 112MPH, 3350LB race weight, unreal for whats done to this engine
Old Jun 23, 2011 | 11:57 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
thanks for the posts, can you give me a ballpark figure on the budget....just trying to decide whether to stay with my L98 and go HSR or just update to an LSX and T56...thanks in advance!
Old Jun 27, 2011 | 04:10 PM
91_rs-teal's Avatar
Engine 66k - had water pump, full intake, and exhaust manifolds on it - $1,200
Trans 25k, Clutch, Slave, Tick Master, Short Throw, PS Pump, Engine Mounts, Pedals, Remote Bleed - $2,000
Swap Mounts, Manifold flanges, and pipes to build a Y - $150
Engine harness and ECU - $250
Belt, Belt tensioner, Alt, Idler, Starter, and all the brackets - around $300
Dual fuel rail instead of running a regulator - $50
Coils, Coil Brackets, Coil Harness's - $100
Walbro 255 Fuel Pump Kit - $100
Coolant Hoses, PS Hoses, Misc. Gaskets, TB, sensors, MAF, and all other misc. things - around $250
new o2's - $100
Cam, Springs, LS2 Chain - $250
Cold Air Intake Setup $100
Also I ported my MAF and TB - $150
so dang near $5,000 I got alot of things used, but if you searched and waited for the deals, you could do a little better.
Find a donor car and save some money
Or you go Auto Trans you can knock aleast $1,000 right off.
Also if you find an iron engine you can save a couple hundred
Old Jun 28, 2011 | 07:17 PM
Car: 91 Z28
Engine: 6.0L LQ9
i appreciate the info....with all the reading i have been doing, i think i'm leaning towards doing a 6.0L LQ4 or LQ9 with a cam, LS6 intake and adding the LS1 accessories. Looks like I may be able to start buying parts...just need to find more room to hide stuff from the wife! haha
Old Jul 15, 2011 | 05:24 PM
91_rs-teal's Avatar
yep, u will love it!
Old Jul 16, 2011 | 05:12 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Well, I'm hoping to join the LS1 crowd too. I've had a good time with the old SBC stuff over the years, but its time to go LSX power and I can't friggin wait!!
I'm working on buying a wrecked 99 LS1/T56 car now, I'll know next week if I'm the lucky (or deepest pocketed?) owner.
I'm just plannong on headers, fuel pump, and clutch for now until I get all the bugs worked out and learn more about the LS engines. With my 4.11 gears already in the 9", I'm expecting a nice running, durable car.
Old Aug 18, 2011 | 06:30 PM
drunck1's Avatar
Car: 1991 Camaro RS TBI Convertible
Engine: V8 305 5.0
still for sale?
Old Aug 20, 2011 | 04:59 PM
jamieschott's Avatar
Exciting stuff man. I ve started on my swap. I can't wait to continue working on it once i get back from school in late October.
Old Aug 20, 2011 | 05:23 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
bellez77
Sep 5, 2015 08:39 PM
InfinityShade
Aug 22, 2015 08:00 PM
reiderz iroc
Aug 13, 2015 04:57 PM
