need help to settle debate
Old Apr 12, 2011 | 06:29 PM
Badasscamaro346's Avatar
Car: 87 camaro
Engine: v8 carb'ed
Transmission: 5 speed
I have been looking into getting rid of my 305 TPI setup. I was told that I could get a complete LT1 and just run it off of my TPI electronics (as long as i mill the hole for the dist into the intake). But I have others telling me that it wouldnt work.
Does anyone know for sure if this will work or not?
Old Apr 13, 2011 | 06:27 AM
kevinc's Avatar
Car: 1982 Z28
Re: need help to settle debate
Are these voices all inside your head, or are they actual people?
Old Apr 13, 2011 | 07:06 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Nope, it won't work
now if you want to put a carb on it, then it would work.
where in FL are you located?
Old Apr 13, 2011 | 07:23 AM
Pocket's Avatar
Car: 91 Trans Am
Yes it will work, but this isnt the best route to take. Dont fogret the LT1 intake isnt flat in the rear so a simple hole isnt enough. Either build up a pad and machine it flat or cut an angled washer to fill the void. The TPI ECM will need a custom flash to run the new engine
Old Apr 13, 2011 | 10:39 AM
Firebat's Avatar
Here are instructions on how to drill the distributor hole for LT1 intake:
http://www.eecis.udel.edu/~davis/z28/lt1intake_conversion/distributor.htm
Thirdgen.org member Z69 was and still might be selling the custom washer needed for the rear distributor for LT1, he had a few for sale months ago.
Also parts will be needed to set the timing such as a balancer with timing marks and the LT1 optispark block off plate/cover with built-in timing pointer. Summit Racing sells the cover here: http://www.summitracing.com/parts/NAL-12367600/ and you can find a LT1 balancer with timing marks (Professional Products 80030) for under $100 on ebay.
In addition to a custom tune, some sensors might have to be swapped with TPI sensors such as the knock sensor but not sure on that.
Old Apr 13, 2011 | 06:01 PM
Car: 87 camaro
Engine: v8 carb'ed
Actual people unless im imagining them as well lol.
As for the machine work to the intake, That isnt a problem, I work at a tool and die shop with multiple cnc machines so i can do all the machine work myself.
I didnt even think about needing tune but i guess it could be an issue trying to find someone who could do a custom tune with a TPI ecm and program it for the LT1. Might just be easier to get a 350 block and build it up with an aftermarket TPI setup.
all in all I guess they were both wrong and both right. Thanks for the help guys
87v6Bird
Jul 1, 2018 04:12 PM
bbsr72
Apr 2, 2016 09:12 AM
LittleFranks
Oct 7, 2015 11:26 PM
Chevykid810
Sep 28, 2015 12:57 PM
HikoriYami
Sep 21, 2015 07:11 PM
