ls1 swap wiring?
Old Apr 26, 2011 | 11:19 PM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
ls1 swap wiring?
If i were to get a complete donor car like an 01-02 z28/trans am and i swap the drivetrain as well as the dash components and the fuel system would i still need to get a wire harness from painless or any other place?
Old Apr 27, 2011 | 01:11 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: ls1 swap wiring?
Not from painless, but there are some connections that would have to be made. Depending on your level of electrical expertise, you might be able to do it yourself. Otherwise, you might consider sending key harnesses to someone like 'Pocket' on these boards.
Old Apr 27, 2011 | 10:28 PM
Car: 1990 camaro rs
Engine: 305 tbi
other connections like what?
Old May 3, 2011 | 03:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The engine harness on a thirdgen has two main connection points:
The C100 (big black connector by the brake booster)
C230 (small black/clear connector under the dash passenger side)
C100 has the wiring for the main power into the car, alternator power, ignition power to coil, oil pressure and temp gauges, starter, etc
C230 has the wires going to the aldl port, speedometer, injector power, etc
As well as the harness having the relay and wiring for the fans as part of the engine harness.
LT1/LS1's use two small connectors along the strut tower, and two small connectors inside under the dash, for all of their connections, as well as the fan wiring and relay locations being part of the chassis side of the harness.
Everything to the LT1/LS1 harness has to be re-routed, to connect to the thirdgen appropriate location, as well as all of the fan wiring and fuel pump wiring be added or brought over from the original harness.
1984HO
Mar 19, 2021 11:59 AM
midge54
Sep 2, 2020 07:13 PM
355sbcTPI
Aug 19, 2015 04:38 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
