F-body manifolds o2 issue
Old May 6, 2011 | 01:07 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
so im usin a set of exhaust manifolds left over from my old 02 z28 on my 5.3l swap and havin some clearance issues with the o2 sensor on the drivers side. the position of it would make it go into the frame. did you guys plug it and relocate them or what? i can get a pic if you wanna see what im talkin about.
Old May 6, 2011 | 01:35 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: F-body manifolds o2 issue
not that my exhaust is done yet, but i found the same thing when i first installed the manifolds. plug the hole and weld in a bung further down the y-pipe
Old May 6, 2011 | 03:56 PM
Car: 1987 IROC
yeah thats what i was thinkin about doin.
Old May 6, 2011 | 04:04 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
I plugged the bungs and set up the sensors on the ypipe. You will prob need the extensions too. I'll post some pics later this week. It was a pain in the dick to set it up. O2 sensors kept hitting the pan and shift lever. The lt headers i have are really made for a manual setup. Pita lol
Old May 6, 2011 | 05:25 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Ill try to get you pics, but I put mine right after the manifolds facing the front of the car. Thats where they had the most space and im not worried about them hitting anything.
Old May 6, 2011 | 06:33 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I havent put my bungs in yet, but I bought a set of bungs and plugs from Summit for cheap and plan on relocating them onto my y-pipe.
Old May 7, 2011 | 11:56 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
that's where mine are. both are just below the collector so there is no need for extensions.
Old May 7, 2011 | 03:59 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
yep, relocat... I put mine where they are real easy to get to under the car. just remember to put them midway up at least in the pipe, mosture doesn't run over the sensors...
Old May 7, 2011 | 10:17 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
is this common that everyone relocates the o2.I havent tried sitting the motor in with the 02 inplace yet.Looks like I better plug the driver side manifold while the motor is still out and buy bungs and extend some wires.
Old May 7, 2011 | 11:18 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
I would like to know too.
Old May 8, 2011 | 02:36 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Summit or jegs sells 02bung plugs
Old May 8, 2011 | 02:58 AM
Car: 1987 IROC
ebay sells them cheaper. ive bought alot of them before.
Old May 8, 2011 | 03:51 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
so is it a common fact that both front o2 sensors have to be relocated when using stock fbody manifolds? I thought only the passenger side needed the o2 bung welded in?
Old May 8, 2011 | 10:20 AM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
When i built my wiring harness i just used the leads from the rear 02's for them.
Old May 8, 2011 | 03:25 PM
Pocket's Avatar
Car: 91 Trans Am
HO2 location, halfway down the 45* bend from the collector flange. For best results the HO2s need to be approx the same distance from the cyl heads
Drivers manifold came with a broken off HO2 already installed. I left it in as a free plug for the hole
Cheap HO2 bungs, go to any local parts store and get a pair of spark plug anti-foulers for large plugs (lawnmowers). Cut off the tip and they work like a charm
Old May 9, 2011 | 10:20 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
This is what i did. Sense i had to take my car to the ref after the swap and the factory cats are really close to the manifold. I plugged the factory O2 bung and welded another bung right next to it. its a tight fit but it works like a charm. Been running like this for 5 years without any problem
Old May 9, 2011 | 10:31 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
wow thats tight lol.surprised it doesnt brake when the motor is revved.what did you do on the passenger side location?
Old May 9, 2011 | 10:43 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
the motor doesnt really move when you rev it. I think for the passenger side, i just used the same factory o2 bung.
Old May 9, 2011 | 10:46 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
iirc the pass. o2 is in the y pipe and not on the manifold. a bung has to be welded in just past the collector
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
69GTOby
Apr 18, 2016 02:34 PM
tommy z-28
Oct 6, 2015 10:58 PM
BLK87Z
Sep 18, 2015 11:29 PM
