What would you do with this wiring?
Old May 25, 2011 | 10:31 AM
ch@0s's Avatar
What would you do with this wiring? First this is not a Camaro its a 91 Vette. I know you vehicles are similar and have been lurking the forum for years.
Your input is greatly appreciated.
Here is my build at LS1 Tech
http://www.ls1tech.com/forums/conver...e-my-swap.html
This bulkhead is just right of center next to my A/C box,
I have decided to clean out this bulkhead and pull the wires under the dash. I will wind them up in case I need any of them later. And delete the rest when I redo my interior.
What did you do to get that crud out of there and what did you replace it with?
I have a ECM and wiring from a 99 Z28.
I am also rethinking my ECM placement if there is enough room under the dash I may route it inside instead of the stock location over the battery.
I also hear the LS1 ECM runs hot. Would it be hotter under the hood on under the dash?
Do you think this bulkhead is big enough to accommodate the left over wires plus the LS1 ECM?
Here is a picture of my old set up you can see the the stock ECM tray above the battery. (right bottom corner of picture)
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
