gmpp head bolt history?
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
has any body had problems with the GM Performance parts head bolts not being able to hold any torque. I was just trying to torque them down at 65 ft/lbs and they were stretching. I even used one of the flexing wrenches to watch it. and it wasn't making it to 60. before any body asks, I did step it up in incriments. I've used them before on my truck engine, and that was at 80 ft/lbs. this is about my millionth issue with this project.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: gmpp head bolt history?
I assume this is on an LT1 as the LS engines are TTY. On another note, I have used the GMPP bolts on various Gen 1 builds with Vortec heads. Zero Issues.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What's a "flexing wrench", and how do you know they were "stretching"?
Car: 86 Camaro Z28
the flexing wrench is the one with the pointer, and as you torque the wrench flexes. It has a big guage on the end, kind of like this one. http://www.summitracing.com/parts/SHC-944690/ here it's called a beam torque wrench.
If they don't hold the torque, then they must be stretching. At least that's what I think.
I think i may have gotton a bad batch of bolts.
Engine: 383 Carb
Transmission: 4L60
"Beam torque wrench" is the correct name.
What does "not holding torque" mean?
Car: 86 Camaro Z28
I guess my terms are a little off. as I was trying to torque with the beam torque wrench the torque wasn't going up like it should. It was sitting below 60 ft/lbs as I was turning it. That's how I can explain it not holding torque.
Transmission: 4L80E/4L80E
You are also lacking specificity. What "GMPP bolts"? Have a part number?
What engine? LT1? LS1? Hope not Gen I SBC, since you posted in the LTX and LSX forum.
Car: 86 Camaro Z28
That's my fault, This is on an LT1 the part number for the bolts is 12495499. I have a build started on proposed lt1 build.
Engine: 383 Carb
Transmission: 4L60
Nothing wrong with a good deflection torque wrench properly used, and unlike a clicker you can see the difference between running and static torque.
Car: 86 Camaro Z28
I used 2 other clicking torque wrenches. the first was a brand new craftsman, the other was a snap-on.
I'm hearing that these head bolts I got are superceded tty bolts. that's just something I don't understand why they did.
Car: 86 Camaro Z28
My term is a little off. The torque wasn't steadily going up when I was trying to torque the bolts properly. It was hovering below 60ft/lbs as I was twisting it. If it was "holding" to me it would slowly go up and not just "hover".
Engine: 383 Carb
Transmission: 4L60
How did you prep the threads? Remember you're compressing the head gasket too so the torque will increase less slowly than you might expect.
Car: 86 Camaro Z28
The treads on the bolts came with a thread sealer on them, and the treads in the block were cleaned. There wouldn't be too much to compress from 50 to 65. some of them torqued properly on the other head, so I had a feel of how it felt.
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Aug 25, 2015 12:54 AM
