4th gen a/c question
Old Jul 14, 2011 | 10:04 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Ok I purchased the hawks kit to use the 4th gen compressor and 3rd gen everything else.. my problem is im using the stock style gaskets for the 4 th gen on the block that goes to the back of the compressor and ive put 2 different sets of gaskets on it and it still leaks.. Am I using the wrong gaskets???
Old Jul 15, 2011 | 09:46 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: 4th gen a/c question
Thos is the gasket im using
http://www.docsblocks.com/proddetail.asp?prod=AC0142
Old Jul 15, 2011 | 12:14 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Crawled under the car and looked while it was running.. Turns out it is not leaking from the block, it is leaking from the compressor itself by the real lower bolt because I can see it bubbling... Guess I need a new compressor
Old Jul 15, 2011 | 12:35 PM
Firebat's Avatar
I use the 0.625 gaskets instead on my LT1 kits which is kind of the same a/c block but looks like gaskets are not the issue.
http://www.docsblocks.com/proddetail.asp?prod=AC0358
Old Jul 21, 2011 | 08:55 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Get you a new compressor and pull a vacuum on the system, pull it down to 29"hg, shut the valve on the vacuum pump and let it sit for an hour. If the gauge has moved within that hour, then you still have a leak somewhere.
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
