charging A/C system?
Car: 1986 Firebird
Engine: 6.0L LSX
Hey guys. Quick question....for those of you who used all the 3d gen a/c stuff with the LS1 compressor, how did you go about charging the system? Did you swap out the metal lines with the R12 fitting for a 134a fitting?
Would one of these things work?
http://www.fm-distributing.com/adapter.html
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: charging A/C system?
I just went through this with my system a few weeks ago. I bought both the adaptor fittings at Napa. They come in a little kit. It's pretty eaisy, just remove the valve cores from the old fittings and put the new ones on. I bought a manifold gauge set, a vacuum pump, 3 big cans of R134a, oil and a can tap for the gauges. Make sure you pull a deep vacuum on the system for 30-45 mins before charging. If you use a manifold gauge set after pulling the vacuum on the system, you can then use that to pull in the bulk of the first can very quickly.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
