LS1 head swap in the car
Old Aug 13, 2011 | 09:06 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well I couldn't find the answer if this was possible with a/c. since im plain tired of pulling the drive line out I decided I would just find out myself. what I found was the a/c box needed the 10mm head fire wall screws removed. two inside for those who do not know
the box does not have to be removed but only moved towards the fender slightly.
then after cleaning and chasing the threads ( in my case I used studs on the new heads) I installed the bottom stud nearest the firewall. installed the head and screwed in the rest of the studs.
Im sure I could have installed all the studs before placing the head on the block but I was concerned with that bottom stud.
had I used head bolts I may have had to remove the a/c box or pulled on it to gain the needed room
as for the drivers side.. well there is a ton of room and there was zero issues
Old Apr 1, 2015 | 07:29 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: LS1 head swap in the car
Almost a 4 year old thread, but this information helped me out. Installing ARP head studs next week for my 150 shot, didn't know if the bottom stud would clear the ac box. Thanks
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
NBrehm
Aug 25, 2015 11:49 PM
reiderz iroc
Aug 13, 2015 04:57 PM
