25% Underdrive Pulley
Old Aug 13, 2011 | 11:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Anybody run one? From doing some searching it seems like a solid 8-10 RWHP upgrade. Alot of people are saying to go with SLP/Powerbond and stay away from ASP. Thoughts? I am just running the stock Vette Balancer.
Old Aug 14, 2011 | 07:45 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: 25% Underdrive Pulley
I bought a powerbond yesterday.. The asp is lighter but id rather have the taller belt ridges the powerbond/slp balancer offer.. and the real hp gain comes from the underdrive itself.. Imo you wouldnt feel a 1.5 lb difference between the two.
Old Aug 14, 2011 | 08:44 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
I'm not all that sure what % of underdrive it is and I'm not even sure what brand it is but my motor had an underdrive pulley on it when I got it. Haven't been able to dyno the car yet but here is a pic of the pulley. Car hasn't gotten a lot of street time yet but I did rev the crap out of it and the belt never came off....
Old Aug 14, 2011 | 10:40 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I've got a 25% UD PowerBond on my car. I can't tell you what the RWHP gain is because it was on there from the get-go.
Old Aug 14, 2011 | 11:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I have one on my car, didn't notice a difference from it beforehand, but I guess every bit helps
Old Aug 15, 2011 | 02:38 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Is anyone having any cooling issues running an underdrive pulley?
Old Aug 15, 2011 | 08:36 PM
xpndbl3's Avatar
Car: 1984 Z28
most people doing the swap are running a cam and steeper rear gears so the motor is turning more rpm anyways. No cooling issues here, but I'm running a brand new water pump, radiator, etc
Old Aug 15, 2011 | 08:53 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
i have the bbk underdrives, and notice no cooling issues at all, but i am dealing with horrible charging issues though. then if i swap to a higher amperage alternator, i think it will just add more load to the equation and completely disregard it even bieng underdriven. lol so idk what i should do. but as for dyno numbers, idk either because they were on before the tune.
Old Aug 20, 2011 | 02:41 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
my underdrive went on smoothly... looks good too
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
