A few questions about mounts and K-Member
Old Aug 31, 2011 | 12:43 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I have a few questions about what I should use for motor mounts and if the K-member needs to be notched at all. Im new to the swap and when I had the same motor in his 87 it was so close to the k-member that you couldnt fit a piece of paper by it. He had solid mounts and adapter plates for stock SBC clam shells. Heres a pic
first question
What mounts should i use?
second question
Do I have to notch the K-Member at all?
thanks
Old Aug 31, 2011 | 12:50 PM
Guest
Guest
Posts: n/a
Re: A few questions about mounts and K-Member
Which mounts do you want to use? Spohn / Hawks? Moroso solid SBC with adapter plates? Stock SBC rubber with adapter plates? ES Poly?
In that pic, it would have looked different with the Hooker 1.25" plates.
Old Aug 31, 2011 | 12:53 PM
6SIX6's Avatar
Car: 89 IROC
in the pic is moroso solid mounts welded to the k member and some sort of adapter plates with stock SBC motor side clamshells. I am getting them with the motor i bought from a friend.
I just dont want it to be like that and that close. Just wanted to know what everyone would reccomend to avoid this or do I have no chioce but to notch the k-member for the pan?
Old Aug 31, 2011 | 01:01 PM
Guest
Guest
Posts: n/a
That still doesn't answer the question. Do you want solid, rubber, or polyurethane mounting?
Old Aug 31, 2011 | 01:03 PM
6SIX6's Avatar
Car: 89 IROC
DOH!!! i forgot to put that in. I perfer poly as ive been in solid mounted cars and its just not my thing really. If i have to do it as I have no choice then I will but id like to avoid solid mounts.
Old Aug 31, 2011 | 01:11 PM
Guest
Guest
Posts: n/a
Then you'll need to order some new stock rubber mounts, and the new poly inserts, then grind the rivets off the stock mounts to replace the rubber inserts with the poly inserts.
Then throw those adapter plates in the trash where they belong, and order the Hooker 12611HKR plates. That'll clear nicely down under, but will be tight up near the HVAC, with the VC and the coils / bracket.
Old Aug 31, 2011 | 01:14 PM
6SIX6's Avatar
Car: 89 IROC
I still have my poly SBC mounts in the car. I was actually gonna take them out tonight as i didnt think I could use them. Good times as I dont have to now. If its close to the HVAC with the coils still clear it. I have a AC delete box if that helps at all. What are you running in your car?
Old Aug 31, 2011 | 01:19 PM
Guest
Guest
Posts: n/a
Go ahead and test fit what you have.
Old Aug 31, 2011 | 01:23 PM
6SIX6's Avatar
Car: 89 IROC
the adapter plates wont let it clear as the solid mounts where welded in at least a half inch farther back in his car. Mine are in the stock location. Im gonna have to run something different I guess.
my original thought was the Spohn mounts and LS1 motor side mounts. Dont know if that will be any better?
Old Aug 31, 2011 | 02:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The spohn mounts should set the motor in the same place as the standard 1" setback mounts designed to work with SBC clamshells. Either way, you're notching the k-member or getting one of the multiple aftermarket pans that are now available.
Old Aug 31, 2011 | 05:15 PM
Guest
Guest
Posts: n/a
With the poly mounts, stock SBC clamshells and Hooker 1.25" plates, there should be NO need to notch anything.
Now that I have the 1" setback in mine, I can see that 1.25" would be best, and the only such option is Hooker. $80 isn't cheap, but bolt-together-and-go has to be worth something.
Old Aug 31, 2011 | 06:22 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Notching makes you feel better, and is probably a good thing to do to avoid future headaches. I'm using the Spohn mounts with stock rubber bushings and while yes...its tight, I'm not complaining.
Old Sep 1, 2011 | 02:56 PM
6SIX6's Avatar
Car: 89 IROC
Thanks guys for the help and so far the hooker plates are what im leaning to as all I need is a quarter inch and im good. I might flatten that side on the k member abit. Heres another option. Is it worth going with a aftermarket K-Member.
What set ups do some of you have on your cars. Im pretty much a newbie to the swap besides what I have read
Old Sep 1, 2011 | 06:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/forums/ltx-...ltx-swaps.html
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
