5.3 Camaro K-member
Old Jul 13, 2011 | 09:13 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
5.3 Camaro K-member
I see that the k-member needs to be notched for oil pan clearance with an ls motor does anyone happen to know how big of a notch is nessesary
Old Jul 13, 2011 | 09:40 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
Re: 5.3 Camaro K-member
i didnt have to notch mine but i am using set 1" back plates. although i did have to grind a little bit away from the edges of the pan
Old Jul 14, 2011 | 12:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I cut mine through the middle of that hole punched in the top of the K-member. As for how wide, I don't recall off hand - just measure the width of the pan and make sure it'll be that wide after you weld the plate back in.
Pics are available - check out the swap list thread.
Old Jul 14, 2011 | 10:25 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i used the setback plates as well, but i wanted a little bit more breathing room on my setup.
i had mine cut back just far enough to still leave the mounting hole for the brake line hold down (maybe an inch or so?). i believe the width was about 11" as well, but its been a while
Old Jul 14, 2011 | 12:23 PM
five7kid's Avatar
This is linked from the swap list sticky:
End result, with Spohn swap mounts:
Old Aug 22, 2011 | 06:36 AM
blakecharles's Avatar
u guys using the ls1 stock f body pan with that notch (that's what I have and plan to use)???
Old Aug 22, 2011 | 06:37 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
correct
Old Sep 2, 2011 | 04:20 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
im gonna have to do the same it looks like. Thanks for the pics to help me out
sweet_87_iroc
Sep 25, 2015 10:01 PM
E Rod
Aug 28, 2015 05:17 AM
nuggie
Aug 25, 2015 01:27 PM
jharrison5
Aug 19, 2015 05:53 PM
NBrehm
Aug 5, 2015 07:57 PM
