L05 truck to LT1, does PCM need VSS?
Old Sep 1, 2011 | 12:08 PM
JaybirdLSSU's Avatar
Car: 91 K1500 Sport
Axle/Gears: 9.5" 14 bolt, 3.42s, open :(
I did search but couldn't find quite what I was looking for. I'm almost done with the swap, just need a tune, opti, and new y-pipe to get it on the road.
Does my 94 LT1 PCM need a signal from the vss to run the engine? Any drivability issues without it at all? I'm keeping the truck's 700r4 and wiring up my own TCC lockup harness. Already have the correct TB and TV cable. I am also hoping I can leave the factory vss/speedo wiring alone since it appears to go directly to the dash/cluster. Any insight at all would be very appreciated!
Old Sep 2, 2011 | 07:39 PM
Pocket's Avatar
Car: 91 Trans Am
Re: L05 truck to LT1, does PCM need VSS?
You will have stalling issue without a VSS
Luckily 91 trucks mostly had 4L60E's, and all of them had the modern reluctor style VSS, so all you need to do is run the two wires to the PCM and one to the buffer box/cluster
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
