getting tach to workwith ls1???
Old Sep 5, 2011 | 08:00 PM
poopman's Avatar
Car: 1988 pontiac trans am GTA
Engine: ls1
Transmission: 4l60e
Axle/Gears: 4:10 moser 12 bolt
i have a GTA with a ls1 conversion, i want to know what is the easiest way to get the factory tach to work with the ls1 conversion. any help appreciated
Old Sep 5, 2011 | 08:21 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: getting tach to workwith ls1???
You may want to update your title with your vehicle info so everyone knows what you are working with. There is a search feaure that is recomended to use before posting a thread, as you can usually find the anwser to most questions by using it. https://www.thirdgen.org/forums/ltx-...a-vin-h-4.html post # 172
Old Sep 6, 2011 | 07:01 PM
Balbea's Avatar
Car: 1987 Trans AM
Engine: Ls1
Transmission: 4l60e
Axle/Gears: 2:73
You need to get the signal wire from the ls1 ecm. Take it over to the drivers side kick panel. Then pull the tach wire out of I believe the C100 connector. which will be a white wire. Now connect the 2. If it works great for you, but mine did not I had to get a 680 ohm, 1/2 watt resistor (radio shack) and spilce into a keyed 12volt source. I taped into my guage feed from fuse box. If you search it I believe Pocket has a diagram posted somewhere. Really simple though, good luck!
Old Sep 16, 2011 | 11:37 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
with above post.I had to do this aswell but still find that my factory tach is reading nearly 500rpm too low.I might trying playing with a few other resistors and see what gets me closer to being as accurate as my autometer tach.
Some guys get lucky and dont need the resister booster method and hook up the tach directly to the pcm,i think it matters which cluster tach is in the car between the 6cyl or 8cyl but dont quote me on that part.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
