LS1/M6 people with dual exhaust....come on in!!
Old Oct 9, 2011 | 08:32 PM
daddy33's Avatar
Car: '85 Camaro
What are you guys using for exhaust routing? I have a Hawks crossmember and want to do a dual exhaust. Either gonna go with dynomax or magnaflow bullet mufflers with a x-pipe and dumped right before the rear.
Just curious how you guys routed your exhaust and if there was any "universal dual exhaust kit" you might of bought and started with?
I've seen a few from summit and was wondering if they will work. If you guys have pics please post so I can get an idea!!! Thanks
Old Oct 10, 2011 | 12:44 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LS1/M6 people with dual exhaust....come on in!!
I bought a slightly used exhaust from somebody just to use to get my engine started and car driving. After things get sorted out I'll change to a different setup. What I bought is duals straight back into Flowmaster single chamber mufflers before the axle and no crossover. This is not the way I would recommend. It will be loud, brappy, and lack balance.
What I am thinking about long term is to place a couple high flow CAT's near the headers because they control sound better than a muffler with no power loss, then go into a Y-pipe to 4" single over the axle to a muffler in the stock location. Without the CAT's this system would be obnoxiously loud.
Old Oct 10, 2011 | 02:37 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Im not part of your fancy LS1 crowd but I do have a T56 with a fancy crossmember:
Dual 2.5 inch pipes
They run into a single 3.5 inch pipe, then over the axle into a Dynatech Splitflow - then out the left in a dump under the bumper.
This is a lowered car, it looks a lot lower in that picture than it really is, but I still think that maybe my clamp there is loosening up and it's lower than it should be. It's still about 4 inches, and the lowest point is the clamp itself.
Single 3.5 inch pipe
To get a better idea of the routing under the car, this is when I didnt think I needed to go over the axle with it... I was wrong.
It's not technically duals, but I think as far as the motor is concerned, it's a dual 2.5 setup. I think a dual 3 into a 4 inch mufflex would be just as easy to do with this crossmember, though. But my engine just didnt need it.
Old Oct 10, 2011 | 08:35 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
infernal, i wish i had your Skulte crossmember!.....
Old Oct 10, 2011 | 12:27 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Every system I have seen with any non-bullet muffler dumping in front of the axles has hung really low. If your car is lowered, ground clearance will be an issue. If you go with bullet mufflers and turn downs you can get a nice system in there.
If you decide to go duals out the back, BMR has a panhard bar relocation kit that provides extra room for running over the axle.
Here is a link to some dual systems.
http://www.camaroz28.com/forums/showthread.php?t=598251
Old Oct 10, 2011 | 05:59 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
shhhh! last time I asked about this relocation bar I was called all sorts of names on here. apparently some of the members dont like the idea and feel they need to control everyone.
Kooks has some nice over the axle pictures
Old Oct 11, 2011 | 11:47 PM
daddy33's Avatar
Car: '85 Camaro
This is almost exactly how I want mine done:
^^^Has same t56 and crossmember is just about the same as my hawks. Only difference would be the headers as those longtubes are from a standard sbc as I have a ls1.
I wonder how much a shop would charge to do a setup like this?
Old Oct 16, 2011 | 03:29 PM
daddy33's Avatar
Car: '85 Camaro
I got quoted the other day for $550-$650 for the above exhaust made with the bullet mufflers included.
I thought that may be a bit expensive so was looking at the summit SUM-642125 universal x-pipe kit. For $90 I think I can't go wrong. The exhaust shop shouldn't charge too much to have these put on right?
Old Oct 16, 2011 | 05:04 PM
Pocket's Avatar
Car: 91 Trans Am
For $650 the shop better include the custom SFCs and coating
Axle dump systems are so simple when compared to over-the-axle systems. Shop just didnt want to do it
Old Oct 17, 2011 | 12:51 AM
daddy33's Avatar
Car: '85 Camaro
Lol, seriously. Summit has this x-pipe kit for $80 now. So I figure any exhaust shop would charge maybe around $200 or so to put it on, assuming there will be some trimming.
I'm even looking at the summit turbo mufflers but curious if that will help quiet it down some, especially compared to the bullet type muffs. Man....what to do!?!?!? Lol
jrdturbo
Mar 31, 2016 02:58 PM
Night rider327
Oct 9, 2015 09:25 AM
IROCNParts
Sep 24, 2015 10:50 AM
Eric-86sc
Sep 22, 2015 08:25 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
