1992 firebird vert 5.3 vortec swap Questions and concerns??
Old Oct 13, 2011 | 05:42 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
Ok I have a 1992 firebird convertible with the bastard 305 and a 700r4 and what Im lookin to do is swap in a 5.3 vortec/4L60e (just a stock motor and trans). It comes with the stock ecm and all the accessories. I have the ram air hood on my car so all the accessories and intake should clear no problem. So my biggest concern is the ECM, can I just use the 5.3's ECM or do I need to convert it? If so how do I go about doing so? Im new to this so any input is greatly appreciated thanks guys.
Old Oct 13, 2011 | 06:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you read the LS1 swap sticky?
Old Oct 13, 2011 | 08:21 PM
Iroc'nthe87's Avatar
Re: 1992 firebird vert 5.3 vortec swap Questions and concerns??
There should be an entry test to access this part of the forum
Old Oct 13, 2011 | 09:03 PM
Engine: 5.0 TBI
entry test?
Old Oct 13, 2011 | 09:30 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Originally Posted by 92FBirdVert
entry test?
See post#2 before asking questions.
Old Oct 13, 2011 | 09:32 PM
Engine: 5.0 TBI
sorry guys..... close this thread.
Old Oct 13, 2011 | 09:45 PM
Sorry if that came off as rude, it was more comical in nature..we just see the same questions every month and they do get repetitive. Anyways check out the LS1 swap sticky thread's as it should give you a great insight of what all is involved with the swap! I'd recommend also searching for any questions you may have as well! Check out some build threads and you'll be able to see the virtual process of putting in an LSX! Good luck and enjoy!
Old Oct 13, 2011 | 09:59 PM
Engine: 5.0 TBI
thanks man its just a lttle confusing to me
Old Oct 14, 2011 | 11:23 AM
You dont convert the ECM. You take the 5.3 wiring harness that plugs into the ECM and break it down and make a few connections between it and the harness from your 305. It's all in the sticky threads if you take a look.
Old Aug 23, 2012 | 10:36 PM
niceguy91's Avatar
Okay guys, I'm a little computer illiterate, how do I find the LS1 swap sticky thread? I've got a 91 firebird 5.0 TBI that needs a new heart, and I've got a 2003 Sliverado 5.3 with a donor card.
Old Aug 23, 2012 | 10:49 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
It is near the top in the Forum section that you posted your thread in.
https://www.thirdgen.org/forums/ltx-...third-gen.html
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
