LS1 power steering pump blues
Old Oct 17, 2011 | 02:40 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
So though having some people think my car is supercharged and dont constantly try to race me.My power steering pump on my ls1 has a phantom leak .Its not leaking from the lines coming off the pump itself or at the connections to the rack.I tried tightening them a lil to be sure.It started randomly about a week ago,and the fluid drips around the alternator.I have no clue how to service these pumps,and replacing them is not cheap.
Has anyone got experience working on them that can point me in what I can try before biting the bullet for a new pump assembly.Thanks
Old Oct 17, 2011 | 02:44 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LS1 power steering pump blues
may be a long shot, but check to make sure your reservoir hasn't gotten cracked or the seal between the reservoir and the pump hasn't some how gone bad.
Old Oct 17, 2011 | 04:30 PM
Pocket's Avatar
Car: 91 Trans Am
Both of mine seeped from the cap
First one blew a pinhole in the pressure hose. New hose and the front seal puked. What a mess
There is an O-ring between the reservoir and pump that doesnt like to get tweaked. The slide clips do a great job of holding it still though, so if you've never had it off, its unlikely the culprit
The return line used a pinch clamp from the factory thats not very tight. I swapped mine with a worm clamp for peace of mind
Also, not what you want to hear but 9/10 times if a PS pump whines, its shot
Old Oct 17, 2011 | 04:58 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Ive never had the pump apart,didnt know it came apart lol.I think it is leaking from the front since it drips near the alternator pulley.The whine happens only when the fluid gets low.Does anyone have an exploded view of how I can take it apart.maybe its just seals that can be changed,not sure.
Old Oct 17, 2011 | 05:26 PM
Pocket's Avatar
Car: 91 Trans Am
Pull the pulley off to get the front seal
Use a screwdriver on the clips to get the reservoir off
Thats as far as you can take it
Old Oct 17, 2011 | 08:00 PM
1quickirocz's Avatar
Car: 88 IROCZ
Engine: 5.3 Gen IV
Transmission: 4L65E
Axle/Gears: Moser 12 bolt 4.10
if the things that pocket mentioned are not the cause of your leak then it is most likely the front seal. pretty easy to do once you get the pulley off. the seal can be picked up from the dealer. Not the worst thing in the world......
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
