So you think this is my problem
Car: Camaro RS
Engine: obd2 350 lt1
I got a itch to take my opti off and check it.
Its however really simple in my car, Total of 30 minutes and here's what I found
All of this troubleshooting the past 2 years looking for a random missfire and randomly running perfect. Hopefully. Do you think that was the problem
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Re: So you think this is my problem
I had one that looked similar to that and it caused similar symptoms to what you are describing. Changed it out and everything was good to go. Mine was on a new GM opti that had less that 1k on it as well. Luckily GM replaced it under warranty because their parts have a 1 year warranty on them. Don't know if they still do that or not, but never hurts to check.
Car: Camaro RS
This unit has 100k plus on it. Of me driving. but i think its been like this all along.
Thinking of doing a cam swap while im in here.
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
So what was it doing for you to take these measures? you didn't say in your first post?
Car: 1989 SS
Nevermind i read under your picture. Goddamn now i want to change mine out, even though it runs perfect...knock on wood.
Car: Camaro RS
Ya while looking at the missfire chart on the ethos it would randomly missfire at idle mostly cylinder 2 and 3.Im guessing this is the area that is burned on the cap. but lately it had gotten worse. I already checked plugs and wires. tested the coil and icm all seemed good. Just bought an accel cap on ebay to get me by till i can do more things at once.
