Coolant bypass LS1 Vintage Air
Old Oct 22, 2011 | 10:51 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
I saw in a thread somewhere, it stated not to plug or block off the heater core lines off of the water pump on the LSs. That they always need circulation. It was in reference of a guy who was deleting the heater core. Is this true, if so why?
I want to install Vintage Air kit and thier bypass valve is only a two fitting. How would I run the heater core lines?
Old Oct 23, 2011 | 07:26 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Coolant bypass LS1 Vintage Air
Use a 3 port valve like stock or the part ghettocruiser posted
Old Oct 23, 2011 | 12:14 PM
Car: 91 z28
Transmission: 4L60e
I cant see ghettocuisers post. The advantage of the Vintage Air valve is it is electric as oppose to vacuum. I want to go to digital cruise as well leaving the brake booster as the only thing that needs vacuum.
Old Oct 25, 2011 | 11:58 PM
Car: 91 z28
Transmission: 4L60e
https://www.thirdgen.org/forums/cool...lve-loves.html
Old Oct 26, 2011 | 08:09 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
https://www.thirdgen.org/forums/ltx-...-valve-ls.html
Thats what I used.
If I understand you correctly, and Im not sure that I do as Im not even sure what kit you are working with...the digital valve is basically just an on/off type of valve?
Ive read some info that says blocking off the heater lines is ok on an LS...and some that say its not. Im inclined to agree that it needs to circulate.
Im not sure how a 3 port valve would work with this set up...but the valve that I used works very well. Downside for you is you'll have to run it off of vacuum somehow.
Have you contacted vintage air to see if they offer any other valves or have any other insight? I wonder if you could adapt the control mechanism to the vacuum operated valve to make a digital 4 port? The actual valve is a mechanical set up operated by the vac diaphram. Might be able to hook the digital set up to it.
J.
Old Oct 28, 2011 | 09:53 PM
Car: 91 z28
Transmission: 4L60e
Look at the schamatic in post #8 of the link I posted (above), it makes my head hurt. Im using the Vintage Air gen 4 but it would be the same for any kit, just the basic concept of hooking up a heater core. The Vintage Air diverter is in/out on/off set up.
http://forums.hybridz.org/index.php/...wout-a-heater/
post #12
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
utfan01ss
Sep 28, 2015 12:17 PM
TheExaminer
Aug 26, 2015 04:59 PM
