LS2 with 4L60e - How do I do it?
Old Oct 26, 2011 | 01:30 AM
Aussie Camaro's Avatar
Car: 91 RS Right hand drive
Engine: Soon to be LSX
Transmission: Soon to be 4L60E
Axle/Gears: 10 bolt 3.23
Hey guys, I need some advice. I'd like to pair up a 6.0L LS2 with a 4l60e trans instead of the 6l80e that came with these motors. What is required electrically to make this happen???
As far as I can tell everything should bolt together fine but I'm guessing that I cant just re-loom the engine for the different trans because the LS2 ecu will not talk to the older 4l60e, correct?
I'm also guessing that I cant swap to an older ECU because the tune will be wrong for the motor and the drive by wire will not work???
This must be a swap that is done very regularly (especially people swapping their LS1 for an LS2). What do I need?
Old Oct 26, 2011 | 06:13 PM
alotquicka's Avatar
Re: LS2 with 4L60e - How do I do it?
6.0 ? the lq9, if so im going to be doing the same thing.
Old Oct 26, 2011 | 07:44 PM
Pocket's Avatar
Car: 91 Trans Am
Over here the GTOs (Holden Monaros) had LS2/4L60E's from 05-06. Its definitely possible. LS2 vettes also used the 4L60E before switching to the 6L60E with the LS3
Old Oct 26, 2011 | 08:47 PM
Thanks Pocket. I guess I'll start looking for a monaro loom and computer. Will any 05-06 LS2 harness and PCM work with my DBW pedal? I heard that they can be quite vehicle specific
Old Oct 27, 2011 | 02:21 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
from what little i have read up on other swap threads concerning dbw.there is a dbw learn procedure that has to be done.pop your head over at ls1tech where ive seen many posts about dbw swaps on different pcms.its a common swap but i dont know the specifics about what works better with which parts and the ease of calibrating them together.
Old Oct 29, 2011 | 03:09 AM
Cheers, I'll have a look
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BDR
Nov 7, 2015 03:05 PM
Nervous2
Oct 8, 2015 10:53 PM
86White_T/A305
Sep 21, 2015 05:28 PM
LSXcamaro
LSX and LTX Parts
Sep 17, 2015 11:17 PM
