LS3 fuel line connection
Old Oct 25, 2011 | 09:56 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Just wondering what most people are doing as far as fuel lines go to their ls motor. I see Hawks sells some adapter lines so you can use your regular lines which looks real simple but a little pricey. Wondering if you guys are using the Hawk lines or what else you might be doing.
Old Oct 27, 2011 | 07:29 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LS3 fuel line connection
you'd probably have more responses over in the LSx swap forum, but I ended up making my own braided lines. however, my car was a factory carbed car, so all the lines would have needed to be replaced anyway. you can make your own adapters pretty easily at home, there's a pretty good chart made by Pocket that shows all the part numbers you should need.
Old Oct 28, 2011 | 04:41 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/post...01-post17.html
If your RS is TBI, you need to read the part with the buffer box too
Old Oct 28, 2011 | 04:48 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Yes it is a tbi. I will take a look at that. What's the original purpose of the buffer box. Thanks Pocket
Old Oct 28, 2011 | 05:09 PM
Pocket's Avatar
Car: 91 Trans Am
Older ECMs were too dumb to decode the VSS signal internally(TBI ECMs are a layover of the old stuff), so the external module does it for them and splits the signal into a 2000ppm and 4000ppm stream for different functions. When swapping in a LT1/LSx, the new PCM is fully capable of decoding the raw VSS data so the box needs to be removed and a bridge inserted to complete the circuit from PCM to cluster
In a nut shell, your speedo wont work unless you bypass it
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
mdtoren
Aug 16, 2015 05:45 PM
86Base
Aug 13, 2015 05:06 PM
