which trans
Old Oct 28, 2011 | 09:38 PM
MMarty71's Avatar
which trans
Hey all, I just bought a 2001 lq4 6.0 and want to run an auto trans. What would be the best trans to run? 700r4 or 4l60e. Also what years can I use? I can find all sorts of 4x4 trannys but no 2wds. Can I use a 4wd trans and just change out the tailshaft and tailshaft housing? Thanks.
Old Oct 29, 2011 | 12:07 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: which trans
https://www.thirdgen.org/forums/ltx-...third-gen.html
Old Oct 29, 2011 | 05:06 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: which trans
of the two options 4l60e is your better bet. if you're open to more options, a 4l80e will take more power than either, but may require a bit of massaging to the trans tunnel to get it to fit up
Old Oct 29, 2011 | 07:07 PM
MMarty71's Avatar
Re: which trans
Ok which year do I need? My 6.0 has the removable crank spacer so the mounting flange is even with the block now.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
