Question on driveshaft and exhaust manifolds
Old Oct 29, 2011 | 02:47 PM
ssantac's Avatar
Car: 83 Trans Am
Engine: Soon to be 6.0l LQ9
Transmission: Soon to be 4L60E
Hi guys,
So my first question is which driveshaft I should use. I have an aluminum 3rd gen driveshaft, steel 3rd gen driveshaft, and aluminum 4th gen driveshaft. I'm going to say the steel one is out of the running for sure, but thought I'd throw it out there since I have it.
My next question is on stock LS manifolds. I bought the flanges that connect to them and the stock exaust pipe looks to be IIRC like 2". Has anyone, or is it possible to increase that size to at least 2 1/2, then step up to 3"? Or is it even possible to increase them to 3"?
Old Oct 29, 2011 | 05:03 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Question on driveshaft and exhaust manifolds
3rd gen aluminum is supposedly heavier duty than the 4th one IIRC
2 1/2 should be doable for the flanges, by may want to do a quick check with a set of gaskets to make sure there's enough meat left to seal
Old Oct 30, 2011 | 07:29 AM
Pocket's Avatar
Car: 91 Trans Am
I cut my flanges from 1/2" plate with a torch using the gasket as a reference. The holes were just under 2.5" when finished
transaero
Aug 31, 2015 01:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Nj1987
Aug 19, 2015 08:26 PM
redmaroz
Aug 16, 2015 11:40 PM
timonator
Aug 11, 2015 09:56 PM
