Stand alone ls1 harness
Old Oct 31, 2011 | 07:32 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I have a totaled ls1 car and want to take the stock body harness and use it as a stand alone engine harness. Does anyone have a diagram showing what needs to be hooked up, I want to hook it up like it would be in an ls car but not useing anything but the engine stuff, the rest will be hidden behind the dash.
Old Nov 1, 2011 | 09:56 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Stand alone ls1 harness
the engine harness is "stand alone" without the body harness but will require modification and the pcm will require a reprogramming. pocket's done a few thorough threads on the subject, so i'd do a search for his name and you should find everything you need. everything else should be here:
http://lt1swap.com/wiringharness.htm
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
ericjon262
Sep 11, 2015 06:07 PM
