How good is my stock radiator for an ls3 swap
Old Nov 9, 2011 | 08:42 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
My 91 Camaro had a stock 305 TBI engine in it. On the hottest days of the summer the stock engine runs very cool. Can someone tell me how many cores the stock radiator has and also will it be big enough to cool for my ls376. Don't want to spend more than I have to. Was looking at a Becool radiator.
Old Nov 10, 2011 | 09:40 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: How good is my stock radiator for an ls3 swap
the stock aluminum radiator should cool enough for a stock LSx motor, as the 4th gens actually got a slightly smaller setup for their LS1s. I believe most of the swap guys are running their stock radiators as well
Old Nov 10, 2011 | 08:27 PM
Pocket's Avatar
Car: 91 Trans Am
Im still running the stock V8 radiator in front of a very healthy engine. No problems
Mine was a TBI car too
Biggest issue with the system is getting a reliable fan and functional air dam. Ive never seen a LSx PCM miss a turn on for the fans and the air dam does its job when you're moving. No reason to swap radiators
Old Nov 10, 2011 | 08:31 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Thanks Jon. That will save me some money that I have to give to you for my harness
Old Nov 11, 2011 | 08:20 PM
Iroc'nthe87's Avatar
Are you staying drive-by-wire? Also what harness do you have for the engine?
Old Nov 11, 2011 | 08:38 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Yes I am staying with fly by wire. I actually got a new harness out of a 2010 camaro plus the original tbi harness. Jon is going to work his magic on it to combine them. Since I bought a new ls 376 crate motor I bought the new computer already tuned for the setup. From what I understand the early pcm's are more tuneable but for now it fits my needs. I will be adding a super charger in a year or so. Hopefully my computer will be able to be tuned for that.
Old Nov 11, 2011 | 08:55 PM
I've heard the opposite, that the newer computers are easier to tune. I believe you are running the E38 computer then (you should be) as thats what the new camaro uses. It will not have a problem being tuned for a supercharged application at all..
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
InfinityShade
Aug 22, 2015 08:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
