Regarding wiring harness - LT1 swap
Old Nov 12, 2011 | 11:50 AM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
87 v6 5 speed. I wanna put an lt1 in it... Now do i need to take out the entire wiring harness and computer? Or is the fuel injector wiring detachable from the harness?
Old Nov 12, 2011 | 02:44 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
re: Regarding wiring harness - LT1 swap
the whole passnager side harness needs to come out with the ecu. the lt1s ecu and wiring harness will replace it, if you keep the lt1 fuel injected. the driver side harness is left alone as well as the ac harness that comes out of the firewall by the ac box. theres are a fw wires that cross over from the passanger side harness to the driver side harness. youll have to fish them out and seperate them.
youll also need a new transmission since the v-6 trans wont bolt to the lt1.
Old Nov 12, 2011 | 02:57 PM
Axle/Gears: 3.47
Is it a pain in the A to get that out?
Old Nov 12, 2011 | 03:17 PM
travis401's Avatar
Car: 91 Camaro RS
to get the harness out, no not really.
Old Nov 14, 2011 | 12:03 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
passenger side harness needs to come out and driver side one has to be modified. i highly recommend checking out the LSx/LTx subforum for posts by Pocket; he's laid out all the info you need to wire these cars up and is very knowledgeable on the subject
Old Nov 14, 2011 | 06:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moved this to the subforum.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
