Transmission lines...
Old Nov 18, 2011 | 01:02 AM
rock861261's Avatar
What is every body using for transmission lines for a 4l60e my 700r4 wont fit and i really dont want to bend a set...
Old Nov 18, 2011 | 01:06 AM
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
Re: Transmission lines...
I used my stock ones.. They were the screw in compression type on the 700R4 and quick disconnect on the 4L60E. Unscrew the fittings from the trans case and swap them. They were the same threads believe it or not. Did this to use my stock lines.
Old Nov 18, 2011 | 01:14 AM
rock861261's Avatar
I tried that and mine wouldnt reach for some reason... the upper was about 3 inches to short
Old Nov 18, 2011 | 05:51 AM
Pocket's Avatar
Car: 91 Trans Am
You sure it wasnt bent upon removal?
Old Nov 18, 2011 | 11:42 AM
rock861261's Avatar
positive... the are actually u and j bends that wont let me get there
Old Nov 18, 2011 | 01:57 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
ended up going with braided lines for my setup. although i really wish i had made that decision *before* installing the transmission. wow are those fittings a pain to install on car....
Old Nov 18, 2011 | 02:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I didn't have any problems mounting the 2000 Camaro 4L60E lines in my car. I have since hooked up an external cooler as well, though.
Old Nov 18, 2011 | 03:45 PM
rock861261's Avatar
I may use an fittings anybody know what size the adapter fitting is that threads into the actual transmission?
Old Nov 18, 2011 | 06:27 PM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
I just checked mine this afternoon and it appears to be 1/4" NPT. I had a 1/4" NPT fitting and it threaded in perfectly. That's with the quick disconnect fitting removed just to clarify.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
