LS1 SWAP SERPENTINE BELT PART # W/ AFTERMARKET CRANK PULLEYNO A/C
Old Nov 15, 2011 | 09:30 PM
Nervous2's Avatar
Car: 1985 TRANSAM
LOOKING FOR PART NUMBER FOR LS1 SWAP SERPENTINE BELT WITH ASP CRANK PULLEY
GOES AROUND CRANK,WATER PUMP,ALTERNATOR,POWER STEERING PUMP AND TENSIONER PULLEY
ANY SUGGESTIONS? PART NUMBERS?
Old Nov 15, 2011 | 09:33 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: LS1 SWAP SERPENTINE BELT PART # NO A/C
It's the stock ls1 belt. The ac pump runs off a separate, short belt behind the main accessory drive. GM made it easy for us non ac guys.
Old Nov 15, 2011 | 09:35 PM
Nervous2's Avatar
Car: 1985 TRANSAM
DO YOU HAVE A PART NUMBER
Old Nov 16, 2011 | 12:54 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
LOOK IT UP ON ROCKAUTO.
Old Nov 18, 2011 | 09:06 AM
Nervous2's Avatar
Car: 1985 TRANSAM
I have a aftermarket crank pulley(ASP) What belt to use?
Old Nov 18, 2011 | 10:56 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: LS1 SWAP SERPENTINE BELT PART # W/ AFTERMARKET CRANK PULLEYNO A/C
Check with vendors that have the ASP pulley. I know thunderracing used to sell them, and they had the belts listed right below it. Or try ASP's site?
Old Nov 18, 2011 | 06:25 PM
Pocket's Avatar
Car: 91 Trans Am
Or measure it. You'll find the PNs for a given application will vary from vendor to vendor since it is subjective from the tensioners throw. FYI, you want to measure with the tension at 1/2 throw, this usually takes a second person
Belt mfrs put the belt specs into the PN for quick identification. Parts store monkeys usually dont know how to read them so dont ask them for a xx" belt
EX of a dayco I shredded:
506923
6PK2345
50 class, light duty
6 rib
92.3" long
6 rib
PK class, light duty
2345mm long
Old Nov 19, 2011 | 05:54 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Dayco: 5060760
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
