lt1 swap headers???
Car: berlinetta
Engine: Lt1
Transmission: t56
lt1 swap headers???
Ok so I am upgrading my 83 berlinetta once again goin lt1 but I'm curious if I can use my oval port headers I know that the lt1 has D ports but wanna know if someone has used different gaskets (for D ports) and not have issues or if an adapter can be made I really don't wanna buy new headers my exhaust system is virtually new
Transmission: 4L80E/4L80E
Most 1-5/8" primary headers will cover the D-ports.
Which headers do you have? You may want to consider welding a bead around the tubes on the outer side of the flange and then gasket matched the flanges. You may need to redo the gasket sealing surfaces on the inside of the flange afterward.
Car: berlinetta
Engine: Lt1
Transmission: t56
Re: lt1 swap headers???
i have a set of summit racing headers on it, and why weld outside the flange? is it cause its a common leaking point?
Car: 1989 Trans Am GTA
Transmission: M28 T56
Heck, my Hooker 2055 shorties with 1 5/8th" primaries work fine.
Car: berlinetta
Engine: Lt1
Transmission: t56
