ls1 VATS
Old Dec 4, 2011 | 07:59 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
ls1 VATS
Anyone using the stock Thirdgen VATS module to run the LS1 PCM? I think im going to change the tune on mine so that it enables with the 3rd gen signal. I'm pretty sure its 30hz. Just curious if anyone else has taken the time to do this little extra security. my thought is its already there and im capable of changing the tune to match the signal so why not
Old Dec 4, 2011 | 09:13 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 VATS
Its not compatible. You can however, leave the 3rd gen VATS intact, but remove the starter relay trigger and move the fuel pump ground trigger to it
I wouldnt put alot of faith in VATS as a fail safe antitheft system. Its too easy to overcome. Having a unique system is better, like the reed switch discussed in the electronics forum
Old Dec 4, 2011 | 09:25 PM
Engine: ls1, LB9
Re: ls1 VATS
why wont it work? you can tune the pcm to work at the 30 hz signal
I just figure if its there its added security easy to overcome yes but some kids trying to take the car is at least enough to slow them down vs pealing the column
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
