Engine mounts
Old Dec 7, 2011 | 02:01 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Engine mounts
Hey guys, Im curious if the ebay set back plates and factory ls1 clamshells and block mounts set the motor farter back and or lower than the spoon mounts do? Also, if I use the set back plates, can I still use the hawks double hump tranny cross member? Will everything still be on the correct angle?
Thanks,
Dustin
Old Dec 7, 2011 | 06:58 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Engine mounts
the 1" setbacks should put the motor in the same position as the original sbc setup, believe the spohn/hawks should be the same
Old Dec 7, 2011 | 08:52 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Re: Engine mounts
if you are using the ebay plates, you need to use your SBC clamshells and engine side mount. you should have no troubles using the hawks dual hump x-member.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
