What filler panel do i need?
Old Dec 23, 2011 | 05:34 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I want to get rid of the holes where the filters are...does anyone make a panel that fills it?
Old Dec 23, 2011 | 06:33 PM
Iroc'nthe87's Avatar
Re: What filler panel do i need?
Why is this in Ltx/Lsx section?
Old Dec 23, 2011 | 07:39 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Most people that remove the TPI put in a gen 3 or 4...thus needing to get rid of that eyesore
Old Dec 23, 2011 | 07:46 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
You could try the Firebird metal panel that goes there. Should pretty much be a direct fit.
Old Dec 23, 2011 | 07:58 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
just get one of a tbi or carb camaro.
Old Dec 23, 2011 | 09:55 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
But a large thin sheet of aluminum, trace out the shape and cut it out with shears, drill a few holes, paint it up and it'll look better than stock. Or buy a carbed car one, thirdgenranch.com sells them I know.
Old Dec 24, 2011 | 01:57 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
This. The firebird panel won't fit without custom fabrication. The black plastic tbi/carb insert for Camaros is the cleanest solution.
Old Dec 24, 2011 | 03:54 PM
Car: 1987 IROC
the top part in this pic!
not my stuff i found this pic searching google
Old Dec 24, 2011 | 10:39 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Thanks guys i'll have to go to the yard and see if i can find one there. Haven't been to a yard searching for parts in over a year!
Old Dec 24, 2011 | 10:53 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
it is a pretty easy fab project out of thin aluminium or plastic if you like to do to do those types of things.
Old Dec 25, 2011 | 07:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should be a dime a dozen. A year? Did you go through withdrawal pains? Any anxiety? Visits to a 'white coat' clinic?
JamesC
86IROC112
Nov 7, 2015 06:50 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
