6L90E
Old Jan 10, 2012 | 08:33 PM
abadv8's Avatar
Car: 1989 RS
Engine: LS1 - HP Tuners Enhanced 2Bar OS
Transmission: T56 - Pro 5.0
Axle/Gears: 9 Inch - 31 Spl Tru-Trac - 4.11
6L90E
I know this has been asked before... sort of. As I understand the 6L90E will not fit without modification. My question is, "How much modification are we talking about?"
I can handle a little tunnel lift, and even a little wider. I'm pretty sure I can trim the interior parts to fit an extra inch or two of tunnel.
Just wondering if anyone has an idea about how much I need to cut and move.
Thanks!
Old Jan 12, 2012 | 11:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have you checked the transmission and drivetrain forum? I haven't looked there personally, but have seen 4L80E swaps discussed (both on that and this forum). The 6L90E should fit as easily with crossmember modifications.
I was considering one for the '57, but will probably stick with the 4L80E since I already have it.
Old Jan 13, 2012 | 07:02 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 6L90E
last i knew (and i may be wrong on this one), the 6l90e was a larger housing than the 4l80e, so the tunnel would have to be enlarged. also, it requires a gen4 (dbw) harness, since it will not work with a gen3 setup
Old Jan 14, 2012 | 12:01 AM
five7kid's Avatar
You may be both wrong and right. I searched around for a long time, it appears the 6L90E is not as big around as the 4L80E at the front (behind the bellhousing), but it doesn't taper off as much in the back, requiring tunnel work. I did see on more than one source that it weighs less than the 4L80E.
Speartech apparently put an LS9/6L90E into a '91 Camaro, but I couldn't find anything about the transmission install itself. Before that they had a 4L70E in it, that didn't require tunnel mods.
silent420wolf
Apr 8, 2015 07:05 PM
S10Wildside
Apr 29, 2013 02:33 PM
S10Wildside
Aug 5, 2010 01:48 PM
007BALT
Jul 13, 2009 03:02 AM
007BALT
Sep 23, 2008 07:08 AM
