Mounting PCM in engine bay
Old Jan 14, 2012 | 06:20 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
I saw the thread about making a hole and mounting it under the dash but my downpipe prevents that from happening, and I have contemplated extended the harness Pocket style, but I really really hate soldering. So who has mounted the PCM in the engine bay or in the fender?
Old Jan 14, 2012 | 09:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Lower left corner of the pic.
Old Jan 14, 2012 | 09:28 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Mounting PCM in engine bay
I have air conditioning so I am considering putting it inside the passenger side fender. Not sure yet how many wires I'll have to extend to reach.
Old Jan 16, 2012 | 08:31 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I am planning on installing my pcm in the same location as five6kid
Old Jan 17, 2012 | 07:14 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you swap out the overflow bottles for a set of the 4th gen ones (washer in front of radiator, overflow under the battery), you could use the area in front of the strut towers as well. i opted to extend the harness and run it through the factory grommet in the passenger fender well.
Old Jan 17, 2012 | 01:45 PM
five7kid's Avatar
On the LS1/T56 car, I have the AC housing, and ran the PCM harness into the passenger compartment without lengthening the harness. I did strip out some unused wires to reduce the bundle size. It would be easier with a lengthened harness, but is do-able with a factory harness. I wrapped the harness in heat shielding tape (the headers are ceramic coated as well).
With the HVAC housing back in:
Old Jan 17, 2012 | 05:32 PM
jamieschott's Avatar
five7kid
Not to hi jack the thread, but...
Is that the Autometer coolant sensor and the adapter for such. If so, is it tightened completely? Which one of the sensors is it?
I have built my harness so that I am using the autometer sensor in the passenger location. Seems as if that particular setup sticks out quite a bit.
Old Jan 17, 2012 | 06:37 PM
five7kid's Avatar
Yes, that is the Autometer engine temp sender. I'm not that fond of it, either. This is tightened all the way. It works fine, though.
I have a combined CTS and engine temp sender in the other car.
Old Jan 17, 2012 | 06:39 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Intimidator used his stock AC heater box, and put it where the condenser would go, hides it very nice. Only works if your deleting ac of course
Old Jan 17, 2012 | 08:48 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
like cprmn14 said mine is mounted in the AC heater box on my 91z. if you lay it a different way and add some sheet metal i believe you can still keep the heater.
Old Jan 18, 2012 | 11:54 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Nice! Thats a slick way of doing it.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
jahblah
Aug 12, 2015 05:54 PM
mizz0313
Aug 12, 2015 06:45 AM
Elliswon
Aug 10, 2015 12:33 PM
