T56 torque arm mount
Old Jan 21, 2012 | 08:19 AM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I've been searching around for a T56 torque arm mount everywhere and can't seem to find one. Has anyone bought one anywhere before?
Old Jan 21, 2012 | 09:35 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: T56 torque arm mount
try ls1tech most of us just run a off trans mounted torque arm since your upgrading your car for performance so no need for it
Old Jan 21, 2012 | 11:17 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
T56 torque arm mount is the same as the T5 mount. Get an 84+ Manual transmission torque arm mount for an F-body and you will be fine.
I would avoid crossmember mounted torque arms. They have been known to rip apart the frame rails where the crossmember attaches, especially with 4th gen transmissions since the transmission mount is 2 inches farther back - it puts even more torque against the mounting holes on the frame rails than a thirdgen trans does.
https://www.thirdgen.org/forums/fabr...hn-torque.html
I would spend the $15 on ebay for the T5 mount or build a custom standalone crossmember for the torque arm mount.
Old Jan 21, 2012 | 11:30 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Im pretty sure I have a used one and a brand new one if your interested. PM me if you are
Old Jan 21, 2012 | 11:35 AM
Engine: ls1, LB9
wow never saw that yet.. im glad I made my own mount and mounting points.. never was a fan of the off set mounts you get from vendors. I will say though Ive seen several tail housing failures and TQ arm failures from using the stocker and stickies
Old Jan 21, 2012 | 11:38 AM
6SIX6's Avatar
Car: 89 IROC
This is why I went with a BMR extreme torque arm
Old Jan 21, 2012 | 12:08 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Thanks for the info. As of now, I have the Hawks conversion crossmember and the T5 torque arm mount that was originally on my car before the swap.
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
