need help with pcm on ls swap
Old Jan 29, 2012 | 04:17 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
ok got engine and harness fiqured out not the problem/questions is i need to have the pcm programmed so i can get the car running and to the exhaust and dyno to finish does anyone have or know where i can send my pcm to have this done i am planning on using a 411 pcm
Old Jan 29, 2012 | 04:38 PM
jamieschott's Avatar
Re: need help with pcm on ls swap
Here is a link in the classifieds of a member that can program your pcm for a fair price so that you can get the car to exhaust and stuff
https://www.thirdgen.org/forums/lsx-...swap-tune.html
Also among the others, a dude named frost over on ls1 tech can as well. Seems to be well recommended. I have dealt with him before when I purchased a Harlan shift light. Very quick shipping and awesome communication. I hear the same on the tunes on these pcm's!
Old Jan 29, 2012 | 06:59 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Send it to the shop that will do your tune and put the money toward the end game.
Old Jan 30, 2012 | 09:43 PM
driver101's Avatar
i am just looking to get a tune to run the car good enough to move it around i hate pushing/towing my car or any car when they don't run it is more hassle than its worth
Old Jan 31, 2012 | 09:42 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
there are a bunch of guys over on 'tech that do mail order tunes, I used Frost and was very happy with turn around time and his attention to detail
Old Jan 31, 2012 | 12:41 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
As stated above..many guys on tech come highly recommended.Id also vote that if your looking to buy a ecm cheap with a base tune to run..spareecm.com was great for me.bought my ecm from these guys on ebay..had everything programmed that i wanted..gearing,speedo,rev limit,tire size,tach etc. and then they let me know that it would be delayed as they were busy so they gave me free powder coated ecm what ever color i wanted and it was clear coated ontop.talk about service.Car started and run great.
Old Jan 31, 2012 | 07:47 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Iv sent 3 over to speed inc for base tunes and they have all been spot on.
http://www.speedinc.com/services.cfm
As others have said frost also does a great job but iv never personally used them.
http://www.tunedbyfrost.com/services2.htm
Have you talked to the place you plan to have it dynoed?
Old Feb 1, 2012 | 09:19 PM
driver101's Avatar
thanks to all for the help i will be talking with frost and speedinc to see
what costs are.but at least i have a idea i had emailed pcm for less and never got a reply back
Ikes 91Z
Dec 9, 2015 03:49 PM
Bstrang6
Sep 8, 2015 04:29 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
