what shifter should should i buy? Help Please LS1 swap
Old Jan 30, 2012 | 02:33 PM
Irocz_fanatic91's Avatar
I have a 1991 Irocz camaro that had an lS1 Engine / t56 Tranny swap from a 2004 GtO and the problem i am facing is the shifter is hitting my center console and i would like to get feedback from the experts. Before i invest in a shifter, what brand is the best that will fit my transmission, center the shifter where it needs to be so that i may finally cover that nasty hole with the shifter plate and boot? please help i got this car 4 months ago....
Old Jan 31, 2012 | 01:21 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: what shifter should should i buy? Help Please LS1 swap
not sure which will fit as i am using a fourth gen counsel. where is it hitting at? sides? the actual counsel or the hole the shifter comes from.
some popular choices are pro 5.0 shifter and the hurst shifter. both sold at hawks
Old Jan 31, 2012 | 04:58 PM
Iroc'nthe87's Avatar
You need to change the offset lever on the t-56 to an f-body one. That will correct your problem.
Old Jan 31, 2012 | 06:02 PM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
i prefer a good hurst billet plus myself.....but i hear the mgw is also a nice product.
Old Feb 1, 2012 | 09:00 AM
I traded my suzuki Motorcylce for my dream car...it already had the ls1 engine & t56 tranny swap from a 2004 gto but the guy didnt have the shifter plate/boot cover on becausethe shifter hits the back of the counsel on 2nd, 4th, & 6th gear on all the way to the right on Reverse....its really annoying and i hate drive my car with a big hole in my center counsel. you say have a 4th gen one installed, what year?
Old Feb 1, 2012 | 09:01 AM
Thank you I will look into hawks third gen. I believe it still has the stock shifter from the 04 GTO.
Old Feb 1, 2012 | 09:02 AM
Thanks for your suggestions...Ill look into both
Old Feb 1, 2012 | 09:10 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
CONSOLE. You need to make sure you have the correct offset lever.
If you want a 4th gen console, anything 4th gen will work but because you have a Camaro, you will need to do some modifications to make it look good. Search...there are a good number of 4th gen console threads here.
As for shifters...I run a Pro 5.0 and I like it. However, had the MGW been out when I was shifter buying, I would have splurged on that instead. Its a nice piece. But you cant go wrong with either. Im not a B&M fan. Had one originally with the donor car...the Pro 5.0 was way better for me.
J.
Old Feb 1, 2012 | 09:13 AM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Like he said, I also have a pro 5.0 and it works great for me
Old Feb 1, 2012 | 09:41 AM
Car: 91 Z28
Engine: 6.0L LQ9
And just for the record champ, there are no 1991 IROC Camaros.
Old Feb 1, 2012 | 09:59 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Originally Posted by ghettocruiser
CONSOLE.
That's funny Ghetto, I was thinking the same thing when I was reading through this
Old Feb 1, 2012 | 10:25 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
i have an mn12 as well, i bolted on a lightly used OE Hurst Pro comp shifter from a 97 T/A i found on ebay for $40, best shifter ive used yet, search around, guy that sold it thought it was just a stock/normal shifter!
Old Feb 1, 2012 | 10:50 AM
ill look into an mgw then bro thank you. As far as the "Console" ill look into the threads here. its a newb question but....Does the shifter have to read its for an 82-92 or will other fbody shifters for t56 trannys fith from 93 and up etc. most of the websites i come across sell camaro shifters from 93 and up
Old Feb 1, 2012 | 10:54 AM
read my post
Old Feb 1, 2012 | 11:02 AM
Ha! that makes alotta sense! this is my third fbody camaro and it struck me odd.... the vin pops up as an 1991 RS....so then the previous owner just got the body or decals from an irocz....Im slowly restoring this car from the crappy conversion they made.....How do you post pics? i just joined two days ago? I appreciate feed back from the experts im quickly learning and have loads of ideas just cash flow is limited lol
Old Feb 1, 2012 | 04:54 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Yup change the shifter cup/lever to a 99-02 fbody on the trans itself.Then get a nice short shifter..mgw being the best out now but pricey..second runner up is the pro 5.0. I came close to grabbing a pro 5.0 when I first did my swap..then found out about the mgw and it will be the first and only shifter I buy in spring when the car is back on the road and I can adjust it properly.
Old Feb 1, 2012 | 05:43 PM
Car: 91 Z28
Engine: 6.0L LQ9
hurst, hurst, hurst....haha, i like the classic look of the chrome shifter, it sits higher out of the console, and i can still shift by just moving my fingers. never used a pro 5.0, but i've had a hurst shifter in every standard tranny car i've owned.
Old Feb 1, 2012 | 06:44 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I have read very good things about the MGW. It sits in a better location than any other shifter on the market. http://www.mgwltd.com/
My lesson learned is do not have anything shiny on the shift **** unless you like to burn your hand in the summer. A chrome rod can do the same thing if you are not careful.
Old Feb 2, 2012 | 03:39 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Oh I learned the hard way as well. Needless to say the chrome handle came off that day.
I reccomend a pro 5.0 personally as I had a B&M before and it wasnt as nice as the pro 5.0
Old Feb 2, 2012 | 07:26 AM
Car: 86 Trans AM
On thing I LOVE about my Pro 5.0...is being able to remove the dang shift handle. I hated that about the B&M. When I have to drop my trans, all I do is pull out the two bolts and remove the shifter handle. Leaves the low profile shifter base on there covering the hole.
The other plus to this is...Ive modified my shifter handle about 5 times since installing it. Ive cut off threads to make it shorter, and Ive put the whole thing in my press and gave it a compound bend. Its bent back and to the left pretty far. Im a tall guy, so this brought my shifter ball back to where its comfortable to me when just cruising. Still slams into gear fine when I need to be aggressive.
I know the MGS has a removable shift handle too. But its like a clamp fit, and Im not sure how much room there is to play with that. Might be even better if you can adjust its height on the fly.
J.
Old Feb 2, 2012 | 12:16 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
I have the MGW and it only contacts the stock 3rd gen console in reverse. Not a big deal at all. Also, I accidentally ordered the 12MM handle instead of the 16mm one. Over a year later they sold me the correct handle and refunded me for the 12mm one after I sent it back.
Old Feb 2, 2012 | 02:18 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Transmission: MN12 T56 GTO
not to sure if u have the situation resolved yet but thought i put my experience in
i too have the 04-06 gto t56
what u need is the 98-02 fbody shift lever to change the offset. the stock gto are 2in farther back. any gm/chevrolet dealer shift can order one for u bout $90(where i got mine). heres a pic what u need(sorry look but couldnt located a pn).once you have the part and istalled the shifter will now sit in the right location. u need the shorter one. after that is installed u can use any fbody 98-02 shifter u want. i have the mgw and no problems in any gear hitting the console.
Attached Thumbnails what shifter should should i buy? Help Please LS1 swap-imagesca7r7z3g.jpg   what shifter should should i buy? Help Please LS1 swap-tremac_dims-968x638.jpg
Old Feb 2, 2012 | 09:00 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Pro 5.0 with a billet ****. feels like i'm shifting with a solid piece of billet....actually it is a solid piece of billet lol
1984HO
Mar 19, 2021 11:59 AM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
