should these manifolds fit a third gen
Old Jan 30, 2012 | 10:46 AM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
http://ls1tech.com/forums/parts-clas...ler-elbow.html
Old Jan 30, 2012 | 10:57 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: should these manifolds fit a third gen
They are just truck manifolds....
Old Jan 30, 2012 | 10:58 AM
TexasLT1's Avatar
Car: '92 RS
If you mean after doing an LS1 swap, maybe. Looks like the outlet would be close to the steering cross bar.
Old Jan 30, 2012 | 11:02 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if using them as a turbo manifold facing forward, looks like on the drivers side they would dump into the steering gear box
Old Jan 30, 2012 | 11:04 AM
89lt1's Avatar
Yes i mean after the swap, lol. I've got a lq4 going in. I know some have done it with 6.0 manifolds. just wasnt sure about what position the v-bands needed welded on to fit.
Old Jan 30, 2012 | 08:45 PM
xpndbl3's Avatar
Car: 1984 Z28
I haven't seen pics of anyone using truck manifolds on a forward facing turbo setup...have you got a build of it?
Old Jan 30, 2012 | 08:48 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
eat it son! lol
Old Jan 30, 2012 | 11:16 PM
xpndbl3's Avatar
Car: 1984 Z28
that's going up, i want down facing like the pics in the first post
Old Jan 31, 2012 | 08:18 AM
TexasLT1's Avatar
Car: '92 RS
Did you miss the part about hitting the steering box with down-facing? You're going to be hard-pressed to find anything other than straight forward or top-mount manifolds that will fit. Or make your own.
I'llrocya
Feb 2, 2016 11:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
transaero
Aug 31, 2015 01:14 AM
theurge
Aug 21, 2015 12:46 PM
