Swap Mounts
Old Feb 1, 2012 | 06:37 AM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
Swap Mounts
Did anybody have any problems when they use the hawks third gen swap mount
Old Feb 1, 2012 | 06:51 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: Swap Mounts
Everyone I have seen use them have liked them. I personally used som $30 ebay 1" setback plates and standard sbc mounts. Cheaper and does the same exact thing.
Old Feb 1, 2012 | 01:20 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Swap Mounts
the 1" plates and hawk/spohn swap mounts are one of the few dead-on, no issue parts of the LSx swap. its everything else that needs work
Old Feb 1, 2012 | 03:50 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Swap Mounts
Was bang on here aswell.Dropping the motor in from the top was fun when I forgot about my pass side coil hitting the heater box :P
Old Feb 2, 2012 | 03:43 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Swap Mounts
I used the set back plates as well and welded solid mounts the k-member and used stock SBC mounts. Everything lined up and dropped in. never even had the passenger coil even come close to the heater box at all. I didnt even have to notch the k member at all and ended up hitting the inside with a ball peen hammer after I flattened the welds and everything cleared good
Old Feb 2, 2012 | 06:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Had a bit of an issue getting the last long bolt through the mount. Didn't matter which side I put in first, it was fine. The 2nd one required some "persuading".
Old Feb 21, 2012 | 07:25 PM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
Re: Swap Mounts
To 6Six6 which 1inch plates and sbc mount did you use. I know a shop that makes mount for 3rd gen ls swap in u don't have 2 notch the k member and their using truck accessories but I'm not trying 2 pay 150 for mounts
Old Feb 21, 2012 | 10:50 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Swap Mounts
2 different sets of mounts, same exact issue. had to loosen up the kmember to clamshell bolts all the way, still had issue, but much more room to play with adjustments.
motor from storage shed to driveway: 5 min
motor from driveway to engine bay: 5 min
installing 2 motor mount bolts: 1.5 hours + a very colorful monologue with the car
Old Mar 2, 2012 | 10:12 PM
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
Re: Swap Mounts
I am trying to use some Dougs headers set back plates and the stock SBC mounts. Is this what you guys are talking about or are you talking the spoon mounts?
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
