untuned 5.3 dyno numbers w/ some nitrous
Old Feb 4, 2012 | 08:32 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Well finally got to see what my car makes on the dyno 272whp/310tq on motor and boy it woke up on the juice, 380hp/430tq. Under the nitrous pull had to let off the throttle because of a fuel leak.
Attached Thumbnails untuned 5.3 dyno numbers w/ some nitrous-imag0188.jpg
Old Feb 4, 2012 | 08:40 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: untuned 5.3 dyno numbers w/ some nitrous
This is useless without some engine specs posted... Is it just a stock 5.3 or what? Those are some sweet numbers though, that is for sure! How big of a shot?
Old Feb 4, 2012 | 08:56 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
It has a 04 corvette cam,springs, and a 100 shot of the NOS brand. This one guy at the shop tried to tell me that the cam i have is too big, i replied "it's not nearly big enough. I know for a fact there's more power in it."
Old Feb 4, 2012 | 09:09 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
An 04 corvette cam is too much? I wouldn't buy an air filter from that guy.
Old Feb 4, 2012 | 09:31 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
... or have my car tuned by him.
Old Feb 4, 2012 | 10:13 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Can you list the mods you've done to the engine?
Old Feb 4, 2012 | 10:42 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
04 Base model cam or Z06 cam? Other mods?
Old Feb 5, 2012 | 08:06 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
The camshaft is a LS6 part # 5308 with the .555/.551 lift and 204/218 on a 117.5. Numbers may be a little off but its close. 255 fuel pump, 8.1L injectors, and LS6 valve springs. Everything else is stock, I even still have the truck intake.
Old Feb 5, 2012 | 08:25 AM
Jim85IROC's Avatar
The LS6 cam is a big improvement over the LS1 cam, but still pretty mild.
Old Feb 10, 2012 | 09:23 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
im curious, is the 5.3 you dropped in an LM7 or L33, based on the #'s your providing im assuming an LM7, which stock has about 285hp, minus roughly 20% through the drivetrain (230ish hp) add the Ls6 cam, and your at 272hp, so it picked up 44ish hp off that cam alone?? That seems pretty impressive for a fairly inexpensive cam... but maybe its just me...
Headers/manifolds? no other mods at all?? Ive just never seeked out the actual gains from an LS6 cam swap into a 5.3, i knew it was a good upgrade but i was lazy.
Old Feb 10, 2012 | 11:02 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
It's a Lm7. I don't have headers, I know if tuned I could possiblely get close to 300 HP at the wheel. I don't think that Dyno was that accurate. The one guy that was doing the pull didn't run it through the entire rpm band. My car really picks up from 5000-7000 rpm. He stop the pull at 6000. I should get a Ls1 intake as well to free up more top end Going to start my turbo build next month hopefully.
Old Feb 11, 2012 | 05:33 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
My video from the dyno pull
http://www.youtube.com/watch?v=Qf8jb...26PMfiPTekaqFA
Old Feb 11, 2012 | 05:43 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Another video this one is a N/A pull, sorry about the horrible sounds and this guy keep talking to me while trying to video. Pretty cool dude. Anyway, the car still needs a tune bad, the car is crazy on the juice. When to the track 1/8th and the car just shut down under nitrous after about 4 secs. And i coasted to a victory of a 04 cobra. Then the it cranked right back up. I think im still flooding it out. This ever happened to anyone else?
http://www.youtube.com/watch?v=MMAkN...26PMfiPTekaqFA
Old Feb 13, 2012 | 10:05 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I have a feeling there is much, much more in it. My 5.3 with headers/LS6 intake did 285 to the wheels, untuned.
Old Feb 13, 2012 | 10:36 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Originally Posted by Willie B.
.....Everything else is stock, I even still have the truck intake.
Truck oil pan? Truck accessories? What hood are you running that allows the truck intake to fit?
Old Feb 14, 2012 | 02:02 AM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
Its because of your tune. Stock 5.3L with 8.1L injectors? You're crazy.
You would be better off with stock 28/lb LS1 injectors then those HUGE injectors. And are you spraying before the Maf? I hope so.
Old Feb 14, 2012 | 07:03 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Not the oil pan, had to use Fbody one and Fbody exhaust manifolds. But everything else is.I'm using a three inch hood cowl. It fits good. But a 4 would have been better. I had to file one of the humps on the alt. down a little. But it fits good now no problems and saved me money. This started as a extreme budget build to have fun in.
Old Feb 14, 2012 | 07:11 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Yeah, I brought them because I started with a used turbo build. And one turbo turn out to be bad so I sold.the good one. And got nitrous but I'm going back to the turbos I got one saving for another. But I'm spraying after the maf, I have a wet shot.
Old Feb 14, 2012 | 09:50 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
yeah man, it needs a tune
Old Feb 14, 2012 | 11:25 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
dude please don't spray that poor engine anymore before it gets tuned. One nitrous back-fire can ruin a lot of hard work and start a nice fire
Old Feb 15, 2012 | 04:26 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Actually just put the kit up for sale to fund the turbo project. NOS wet fogger system , 10lb bottle, purge system, bottle warmer, pressure gauge, and WOT/window programmable switch/ 100 hp jets and 150hp jets. For reasonable offer any interested buyers?
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
MRZ28HO
Southern California Area
Feb 19, 2003 12:06 AM
palric
72
Oct 19, 2002 11:33 PM
NOSFEDGTA
Feb 9, 2002 01:54 PM
NOSFEDGTA
Jan 24, 2002 02:24 AM
