proposed 5.3 build
Old Feb 17, 2012 | 11:40 AM
protestthehero's Avatar
proposed 5.3 build
Hello everyone
Ive been trying to get everything in line for my 5.3 build and I was wondering if I could get some opinions. I have a 2000 lm7 thats apart and im rebuilding with new rings bearings and gaskets. I have a set of mildly ported ls6 heads im going to have milled 0.030 to match the compression of the other heads I have. with a set of good dual hive springs, I want to use the tr220 cam as I see it having the best gains for a off the shelf cam. paired with an ls6 intake, and a 100-150 shot of nitrous, I plan to see upper 400 lower 500 hp and torque to the wheels. does this sound correct? im open to all opinions
Tyler
Old Feb 17, 2012 | 01:59 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: proposed 5.3 build
Take the mods your doing and estimate the gains from those on the low side and then read this thread posted a few days ago, should give a rough estimate:
https://www.thirdgen.org/forums/ltx-...-5-3-dyno.html
Wouldnt hurt to watch a few stock/mild 5.3 dyno Vids on youtube, collectively they should give you a better estimate.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
ZEEYAA
Apr 16, 2023 08:29 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Jlanz55
Sep 29, 2015 08:55 AM
