Has this ever been done?
Old Feb 18, 2012 | 04:18 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I put a 3rd gen fuel gauge in a 4th gen gauge cluster. Do you see any reason this wouldn't work?
Attached Thumbnails Has this ever been done?-img-20120218-00061.jpg   Has this ever been done?-img-20120218-00063.jpg   Has this ever been done?-img-20120218-00062.jpg
Old Feb 18, 2012 | 04:19 PM
Brando5641's Avatar
Re: Has this ever been done?
Tell me what you think.
Old Feb 18, 2012 | 09:19 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
My first instinct is that it won't work. The thirdgen cluster gets its fuel info straight from the sender. The 4th Gen gets its info from serial data provided by the PCM. IF...IF...you can tap into the 4th Gen cluster so that the sender goes straight to the modified gauge section, it should work.
So it depends where the signal goes once it enters the cluster. Tho, since you already modded it, you could just bypass all internal circuitry and run the gauge that way.
I like the idea...let us know if you get it working properly.
J.
Old Feb 18, 2012 | 09:34 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Cool idea. Is the sweep the same on the 2 gauges? If not your readings may be off.
Old Feb 18, 2012 | 10:09 PM
Brando5641's Avatar
it looks to be very close. Im not sure how i am going to get out the pinouts to wire it up but the fuel will have its own wiring from the factory wiring harness.
Old Feb 18, 2012 | 10:14 PM
Brando5641's Avatar
I got a question ( i need help pocket)
I got my truck harness modded for a stand alone. How will i wire up my gauges? Will i have to get the pinouts and put pins in for the gauges? Im not sure what all is removed when this is down but im guessing all that will be there is just enuff for the car to drive.
Old Feb 22, 2012 | 01:32 PM
silent420wolf's Avatar
Car: 92 Camaro z28
Engine: LQ4 6.0L Vortech w/ aluminum heads
Transmission: 4l60e
Axle/Gears: 3.42s from 99-02 WS6
your standalone truck harness is all underhood. it has no direct connection to your fuel guages. i like your idea here so detail it for others or maybe do a sticky.
Old Feb 22, 2012 | 02:12 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you're using an "LT1" gauge cluster, it gets wired to the sensor outputs in the C100 bulkhead. if you're using an "LS1" gauge cluster, its serial data that has to come from the pcm (add a wire or two)
Old Feb 24, 2012 | 02:57 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Did you happen to swap to a 4th gen tank? i assume no, it would be two nice upgrades to the car, new plastic rustproof gas tank and an updated dash w/a working fuel gauge.
Old Feb 24, 2012 | 07:16 PM
Brando5641's Avatar
No im going on the super cheap. Im tryen to get it goin for turdgen fest. I will one day get a 4th gen dash in it and the plastic tank but for now i just want to get it running good.
