LT1 oil pans
Old Feb 22, 2012 | 08:22 PM
jaben2's Avatar
LT1 oil pans
I currently have a shortblock assembled. I am getting ready to put top half, and oil pan on.
Question is I see the B body, and F body oil pans look to be the same. I have a B body oil pan currently.
Is it worthwhile upgrading to a aftermarket oil pan, or stay with the b body, or get a new f body oil pan?
Engine is going into a 85 trans am.
Thanks,
Old Feb 23, 2012 | 02:24 AM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
Re: LT1 oil pans
That really depends on what you plan on doing with your car.
My LT1 has the stock oil pan on it, and works perfectly fine on the street and at the drag strip and occasional twisty runs with 450+ N/A HP.
However, if you plan on road coursing the car often, I would highly suggest an aftermarket pan with kick-outs.
Old Feb 23, 2012 | 03:03 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: LT1 oil pans
IMO use the stock oil pan. Spend your money on the heads
Old Feb 23, 2012 | 04:49 PM
jaben2's Avatar
Re: LT1 oil pans
already have heads, just was curious what people were using/
Thanks for the replies, will probably just pick up a new OEM oil pan then.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
