LS1 Fuel Regulator
Old Feb 25, 2012 | 09:44 PM
pacamaroman's Avatar
Car: 1983 Camaro Z28
Engine: soon to be an LS1
Transmission: soon to be a T56
Axle/Gears: 9 inch rear 3:70
LS1 Fuel Regulator
Hi Guys! I'm getting ready to purchase my fuel lines, pump, and regulator for my LS1 swap. I'm planning to utilize the Corvette regulator setup exactly as described in this thread: https://www.thirdgen.org/forums/ltx-...-tank-ls1.html
Here's my question: If the Corvette regulator is mounted in the rear under the fuel tank as I assume it is designed for, wouldn't the fuel pressure suffer somewhat at the motor compared to having the regulator located in the engine bay? The "regulated" fuel has to travel like 12 ft as opposed to like 1 ft. I'm just a bit worried that on a quarter mile blast with a high HP engine, that it may starve for fuel.
This setup must work very well because the corvette's come from the factory with it and a lot of people are utilizing it. It's just something I was pondering. I apologize for my ignorance, I just want to understand it better. Thanks in advance for the responses!!
Old Feb 25, 2012 | 10:40 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: LS1 Fuel Regulator
The entire volume of fluid stays pressurized. Much the same way hydraulic brake systems work. The calipers don't see any less pressure than is applied at the master cylinder unless something flexes/bulges in the system.
Old Feb 26, 2012 | 01:58 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yes, you answered your own question. What size injectors are you using?
A fluid won't flow unless there is pressure difference from one end of the line to the other. There will be pressure drop across the whole line when engine running. As long as the fuel pump can keep up and fuel lines are of sufficient size, then you should be fine.
Old Feb 26, 2012 | 04:46 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
its more than adequate for most basic and mild build lsx swaps. its when you start running higher horsepower levels that people look into doing a more complex fuel system to keep up with fuel demand.
what power levels are you planning on building for?
Old Feb 26, 2012 | 08:26 PM
Thanks guys for your responses. My plan is an LS1 with either TSP LS6 stage 2.5 or 5.3 stage 2.5 Heads (not sure which yet, ordering cam and heads later in the week) MS3 cam or close, Fast 90/90. I'm hoping to be near the 450 rwhp mark. I haven't researched injector size yet, but I'm thinking 42 lb maybe? I figured that fuel line setup would probably be allright for me, but I guess that I see most regulators mounted up front near the engine. I thought about trying to keep the option of nitrous open, but honestly I doubt I'd ever install it. Ohh and I was planning on using 6AN.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
